3.0tdi Serpentine Belt Replacement
MarkW73 Oct 11, 2018
  1. MarkW73
    MarkW73 Member Team Phantom Audi A4 Audi Avant Owner Group S-line owners group
    68
    Hi all, my A4 sounds like it has a supercharger fitted and the mood is coming from the front right of the engine. Everything is working okay but i’d like to change the serpentine auxiliary belt and tensioner.
    Does anyone have a how to or can give me a method to change them?
    Is it possible without removing the front of the car?
    Cheers, Mark
  2. Avatar
    Google AdSense Advertisement
  3. Paul battams
    Paul battams Active Member VCDS Map User
    144
    39
    Hi I’ve only ever changed belt with front off but I’m lead to believe you can do it if you remove bumper and draw the front panel forward on long bolts you gain about 40-50 mm access is still tight but doable I think they’ll be someone on here who knows
    Good luck
  4. OliNix
    OliNix Active Member
    280
    81
    You have to remove the front bumper and put the front end in the service position. Then you need a breaker bar and a large torx bit to be able to slacken off the tensioner.
    After this you can remove the belt and replace and tensioner if you wish, it is only 2 more bolts. Tbh it is highly unlikely it is the belt causing your problems. More like the alternator......
  5. OliNix
    280
    81
    It could also be one of the idler bearings. A quick spin will tell, you will be able to feel a bad bearing
    If you pm me your email I will send you the Audi service instructions
