Q7 Air suspension
perukmakaren
Q7 4,2 TDI-2008
While driving the car lowered itself from comfort to dynamic, I wasn´t driving fast enough for it to do so properly.
The yellow warning light with a car and a downward arrow came on.
It doesn´t respond to any settings in the mmi even though the different modes aren´t grey.
It doesn´t respond to the buttons in the back for lowering it to loading mode.
I´ve checked for fault codes with vcds but there are none. The 5A and 15A fuse is ok.
I´ve had it Indoors in my garage over night but no difference.
Shortly before I´ve changed tires and had it in jacking mode.
The car is leveled so I don´t think it´s something wrong with the height sensors?
I´m thinking if the relay has hanged up and thereafter burned the compressor?
Is there anyway to check the relay? Ohm measure it to see if it´s faulty maybe?
How can I check the compressor?
Big thanx in advance!
Greetings Johan.
The 40A fuse under the seat is ok.
The rear seems to be in loading mode and the front in dynamic.
I have the following fault codes:
01250 Function deactivation, valve duty control 001 Upper limit exceeded
Time 15:03:59
01400 suspension level control 002 Lower limit exceeded
Time 15:13:40
01583 Leak in system detected 000 Intermittent
Time 16:27:46
01770 Temperature sensor for level control 008 Implausible signal
Time 16:38:56
Ok, not the best forum in the world I´m guessing..
I bypassed the relay and the compressor still didn´t work.
After taking it down I get why, the wires were damaged right were they go into the compressor.
