Light swith replacement ?
griffin1
SE Ldn/Kent
Website
www.kontraband.co.uk
Hi,
Past couple weeks whenever i put on dipped headlights, the fog lights come on at the same time - the switch is obv faulty as its one more click out to put them on normally.
Anyone else ever encountered similar problem ?? how much to replace or how diff to attempt myself.
Appreciate any help.
Rgds
you can remove the existing switch in two minutes, simpley press in and turn it left, it should then slide out
ok - i lied that'll take ten seconds - maybe make a cup of tea as well
thanks for info - very helpful
Yeah, I've got the same problem. Been on the lookout for a replacement switch - was one on eBay a while back but I was outbid. Just living with it at the mo and got used to pushing the switch back in to turn off the front fogs after I've turned on the lights.
I definitely don't want to go for the Peugeot/Citroen look of 'I must have front fogs on all the time'....
I still have my old switch somewhere if anyone needs one, it works absolutely fine, the only reason i changed it was that it got scratched by a mechanic during a service so i thought i'd replace it.
pm me if you're interested
