A3 8p double din dash
Matta3sline
Hi guys does anybody know if the facelift 2011 centre console ie hazard esp and blanks would fit 2006 dash thanks
From what I understand it will fit if you have a double din cage but the cage will need a little trimming as its a pre-facelift cage.
I am also about to do this change including 2011 switches. I would like to know if the plug is the same as the pre facelift 8P1?
I have a facelift cage too and was wondering if that also will fit my 2006 only got it as it was cheap sp worth the chance
Ahh cool so you recon if got the facelift set of switches ect that wud work too
I had a 10 plate facelift double din cage with the the butons hazard,traction and airbag warning light i fitted it to a 2006 car everything fitted and worked i only had to trim the climate unit abit on both sides
Reactions: Matta3sline
Thats good news thanks bud did you fit aftermarket double din into yours. Just wondering if you have to buy the double din fitting kit or weather just a fascia panel works
