CODING ISSUE WITH XENON HEADLIGHT CONVERSION *RETRO FIT* HELP!!
clinton mck
ill explain a little , ive had these lights put in some of you might have seen my earlier posts but i got them in and the lights coded to work on low beams and the led strip to work as parking lights the man who coded it completely removed the option for DRLs on the infotainment system , its a nuisance kind of regretting putting them in but i feel theres a silver lining somwhere ... i then got the wires connected from the adapters to the light module for the full beams and the coding done for that which is the part that says 5D 5D , still nothing , this is my last resort before i just go back to the original headlights , can anyone please give me the required coding and ill pass it on to the mechanic .. it would be very much appreciated ! nobody seems to know what to be at yet have the vagcom for these cars and im driving long distances to get work done to no avail ... thank you
Would it be the same as coding thats fitted with xenons from the factory? Can grab the code off my black edition if it helps?
is there nothing in the long coding helper have you gone down each bit and looked for it ? when i activated drl on constant i swear the options were in the module.
see the first man i went too f**ked up and he set my car to american standards where i was driving around with the break lights as indicators then i went to him again and he changed it and removed the option for drls yeno on the on board computer , at this stage i hadnt the wire for the full beams in so there the other day when i got them in we changed what the manual said to mind you i havnt a clue about this i stood and watched , but nothing happened and still theres no options , if i could revert it all back to standard and then get somone who actually knows to have a look its been a torture
the lights are genuine audi the car is 2011 se ? it could be worth a try im due mot and need some sort of fix !
buy vcds its invaluable. obvs cant talk about where to get it from but genuine on here but wink wink a certain online auction is where i got mine from
Should definitely be possible. Google will help a lot aswell. Plenty of information out there.
sorry havnt been on in a while , recently got the original halogen lights put back in what i have noticed now is two bulbs on each side of the car are not working in the DRLs and also the option for exterior lighting to turn on or off DRLs is now gone , this has been a nightmare lol it will pass mot now but just the two outer bulbs on eachside isnt coming on , any suggestions ? possibly a coding issue ? i may change the bulbs soon and see how that goes
the lights inside the yellow box on this picture i found on google
