I hope somebody does correct youCorrect me if I'm wrong but i think it is a right pita to remove the rear spoiler
Must be bolted ..... Can't believe they'd leave it just down to some bonding ..... After all people can potentially put a lot of weight on these thingsI'm sure the original ones are either bolted and bonded or just bonded with something like tigerseal or something similar, it will come off but not easy.
Are we talking about the same thing ?Must be bolted ..... Can't believe they'd leave it just down to some bonding ..... After all people can potentially put a lot of weight on these things
Sent from my SM-N9005 using Tapatalk
A lot of weight on what ? I know that on the a3 Slines they are bolted and sealed, so must be the same for all. But most aftermarket ones are only bonded on, it puts up a tough fight ! It's on there a goodun' once they have been bonded onIt will be the same drop either way I would of thought? I had s line suspension and have fitted sportlines and the drop is perfect and I have 19" wheels so I wouldn't worry too muchAmazon screwed up the delivery so still no vinyl
If anybody has a B8 on 18" alloys can you measure the heigh from floor to the centre of wheel arch on body please? My car feels low alongside others and it only has a standard suspension (I think). Worried dropping it a further 40mm on the Eibach Sportline's will be too low!
ta
Well that all depends on what "too low" is? I don't get any rubbing and can get over speed bumps. Doesn't look boy racer-ish at all. Take a look at my thread to get an idea of the drop if you like.Just worried that the car will be too low!! It already sits low for a family car.
Thanks! Yeah no problem. Another solution to that would be get bigger wheels? Still have the look of the drop and smaller arch gap but with the underside of the car being higher?thanks @James.B8 .....The drop looks great.
I think it's the general height of the car off the tarmac that worries me, not so much the gap between arch and tyre. Hence why I wanted a reference from another car of tarmac > arch/fender height.
Getting old now and want to save my back
ALthough the kids will get in no sweat!!
thanks again!
I believe so. Those are the measurements I used when putting the black badges on mine. The panel on the right is the door so that would be the passenger side. I'll go take a photo of mine for reference.Just plotted those measurements on my front wing and they don't appear to be right (in relation to what you can see on the pic) - is that definitely from a B8 4?
The panel on the right in your picture is confusing me as there shouldn't be one there - certainly not in a shot that close!
It could be me being dim!!
Nevertheless, have used those measurements and got it in what I think is the correct posisiton, especially going off my Q7 S-Line.
WIll post a pic once I've juiced my phone![]()
Nothing wrong with trying new things.Think I don't like it either... Only did it on the one handle and will be removing later
Only cost a quid for the stickers!
