HELP!!! with some fault codes please
S
Scottamdaddy
Guest
Hi Guy,
So I now have VAG-COM I done a scan and this its what has come up if any one knows what they mean input would be great... or what they are and what they do?
the car is a Audi A4 B6 1.8T 5 Door Saloon :)
Mileage: 249160km/154820miles
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0304
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 G
Component: KOMBI+WEGFAHRS. RB4 D21
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0504
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AJ
Component: Komfortgerát T9F 0619
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 4.11
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 4.11
14 Faults Found:
01134 - Alarm Horn (H12)
01616 - Signal Wire to Interior Monitor
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01561 - Rear Left Door
59-10 - Can't Unlock - Intermittent
61-00 - Won't De-Safe
01562 - Rear Right Door
01559 - Drivers Door
01331 - Door Control Module; Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
End ---------------------------------------------------------------------
I cleared the Faults and got this back
1 Fault Found:
01304 - Radio
Any help would be good guys thanks for your help :)
Yeah that is why it can't find the communication, it is looking for Audi head unit.
If none reappear then you're all good. Keep checking and see if any come back.
