- Joined
- Nov 30, 2014
- Messages
- 503
- Reaction score
- 359
- Points
- 63
Audi a3/s3 door pocket lights guide.
Firstly, here are all the items listed below; that I used throughout fitting the door pocket lights.
1) First step, removing the door card.
2) Drilling your door card.
This is how I done mine;
passanger side above........drivers side below
Thanks for reading. I hope you understood these steps (as you can probably tell my english isn't the best
Any questions please ask, will be happy to help.
- T20 Torx
- Flat head screw driver
- Small file
- Trim removal tool
- Drill
- Soldering iron
- Solder
- Wire cutters/strippers
- Insulation tape
- drill bit
- masking tape
- pen or pencil
- The lights and cables themselves (link below)
- remove speaker grill with flat screw driver or trim removal tool ( The speaker grill is really delicate and fragile, so do be careful).
- next, remove the three T20 Torx screws.
- Place the trim removal between the door card and the door and pop the door card off from the bottom and the sides, then lift the door card upwards.
- Then remove this connector.
- Lastly, remove the door handle cable.
- Firstly, sketch the circumference of the door pocket light on a piece of masking tape, then stick in place onto your door card. ( This will be used as a guide for when your drilling your door card).
- Once the masking tape is placed onto the door card, use a drill to drill out the inside area of the outline of your guide.
- Test fit your light, to make sure it fits.
- Once you are happy its sitting wright; tidy up the edges with a small file.
- I wired mine to the window switch, as i figured this would be the easiest way to do it. This is because, the door pocket light will come on automatically when you switch your headlights on.
- Remove your window switch.
- Use a set of cable stippers/pliers to strip back the wires.
- Then solder your live (red) wire to the live wire on your window switch (blue). Then solder your negative to the negative (brown) wire on your window switch.
- Then use some insulation tape to tape the wires up which you have just soldered together.
