3.0 tdi v6 swirl flap delete
ferritt
Is it possible to delete the swirl flaps from the ecu? I'm getting error messages from both banks and rather than repair i would just sooner get them deleted. Has anyone done this and how did it work out? Also is it possible to leave the swirl flaps in-situ in the manifold even when they have been deleted, i understand their default position is open so presume it would be ok just to leave them.
The flaps run inside plastic guides and they normally wear through. So i would recommend removing the flaps and then kill the flaps in the ecu.
Is there a "How too" for the delete??
How do you "kill the flaps in the ecu?"
When you remove them it'll throw a error up but will that put the car in limo mode or is it just a light in the dash?
Most of the time replacement of the actuator rods is all that is required to resolve this issue. That's what I did on my car and haven't seen any more issues. They don't present any issues unlike swirl flaps on some cars such as the BMW's where they can be ingested into the engine.
http://www.ebay.co.uk/itm/Genuine-A...nifold-swirl-flap-link-arm-x-2-/252672826243?
To remove them completely requires a remap on the ECU
Karl the reason why the arms come off is normally due to the added load being put on them from worn out bushes in which the swirl flap rod rotates within.
The last two deletes I've done the bushes have worn straight through
Sorry to revive this thread but seems he most relevant
my swirl flaps are giving me issues, bank 1 the rod has detached and is super worn so will fall off again, and on bank 2 I’m getting the engine light on, so instead of repairing I’m thinking of physically removing them from the manifold but my question is can I take the swirl flaps out and leave the actuators plugged in so the car still thinks it has flaps and still moves the motor it just won’t be connected to anything?
I should probably include that it’s on a 2009 B8 with the CAPA engine code
Yes that's fine to do as long as the motors are working fine
Reactions: Cliffy
i have in my shed a single set ( for 1 bank) from my q7 casa , engine flaps / rod / bushes/ ball joint , if anyone wants the set for free plus postage (£2) to get their problem sorted.
i bought 2 sets and only needed 1 in my 2 year ownership of the q7 ( wish i still had that motor) anyway my a7 cduc is a totally different style and dont need the older type anymore
no the motor rest position will be different hence why the worn parts are making it throw the code in the first place.
its like returning to a negative rest position
@bobby singh whats the issue of them wearing through? Looking to get a swirl flap delete without removing the flaps and wondered what the possible long term damage could be to the engine if any
I see cars like this all the time whereby so called tuners just turn off the flaps but do not remove them. I had a case recently whereby a CAPA had no error code but the customer was complaining of low power. Well turns out the flaps for the RHS bank were stuck at 80% closed but off course no error codes so his local garage had no idea why the car was down on power.
Do the job correctly and you won't have these issues.
SO can I remove the flaps and linkages physically from the inlets while i'm having a decoke and clean , fit the limiting stainless brackets, then leave the flap motors plugged in and then drive the car error free? what's the downside to this?
Holy Thread Revival, Batman!
Quick question on this subject if I may?
Audi Q7 2008 with a CASA engine code...
I've done the physical delete from the intake manifolds, new gaskets and reassembled etc. Physically all good and I'm happy with my own work as normal.
Software question - if I try and drive this to a local tuner (not of Bobby's calibre, but just a place to give a cheap Q7 a flash remap), is this thing going to have a tantrum at me if I physically disconnect the swirl flap motors at the connector and do away with the swirl flap motors all together BEFORE the remap?
Might limp but will be ok to drive .
I also do postal service if you get stuck
Bobby, it's Scott on the Isle of Arran.
The Touareg will be coming down to you when I establish my itinerary but this Q7 is a bit more of an ugly donkey. It's not worth the calibre or cost of your work Sir. This would be "below you"
Limp I can deal with. It's only 20 miles to the local flash-mapper and my expectations of the result are not that high. Quite simply "some" improvement of power/torque/economy would be a bonus but the important bit for the Q7 will be the EGR/DPF and swirl flap deletes.
Plus, he does powdercoating/wheel refurbs and he's actually very good. He bundles a remap and alloy refurb for a very handsome price, so he's doing some wheels for me currently and the Q7 map is basically "free" in my eyes.
