How To - Red RS3-Style Air Vents
Max-Robbo
Selby
Evening all, thought a How-To might be helpful for some people..
Following @zippster ’s recent thread about buying red air vents (and other items) from the RS3, I thought I’d have a go at red-ifying my standard vents (couldn’t stomach £250-300 for the OEM RS3 parts!)
A couple of pre-cursors:
- Yes i know there’s only three pictured, I trialled the first last night ;)
- DIY at your own risk, if you break something don’t blame me, just super-glue it back together!
- Apologies for the Bravissimo dust sheets, it’s all I (the Mrs..) had lying around…. Honest.
- Take your time, the plastic is quite thin in places.
- I have no affiliation to Homebase…!
- Thanks to @zippster for the inspiration, to @Rob2k68 for pointing me in the right direction for some vent removal guides, and to @pburv for encouragement (“Hurry Up!”)
Needed:
- 20-40 mins & drying time, depending on dexterity..
- Spray paint (whatever colour you want, just make sure it’s suitable for plastics), I used http://www.homebase.co.uk/en/homeba...l-spray-paint-cherry-red-gloss---150ml-232460 - the red has come out quite nice, £5 well spent
- Ideally two mini flat head screwdrivers (Christmas cracker ones for me...!)
- A couple of pieces of card to use as wedges
- Very small sanding file - I used a nail file
Here we go, my first How-To so cut me some slack!!
First, use your fingernails or a trim tool to prise the air vents out of the dash (the back end of an ice scraper helped me a bit). The surrounding material will bounce back so don’t be afraid to use some force.
IMG 4081
On each of the vents, there’s a coloured dot to mark the top. I wrote L (Left), ML (middle left etc..), MR and R on the corresponding vents to put them back in the right place - optional as they’re all the same but hey.
Turn the vent upside down and use a pair of needle nose pliers (or tiny fingers) to pinch the clips together to release the ‘ball’ from the outer casing
IMG 4090
Pull the diffuser forward to bring the flaps together, and, from the back, locate the small T clips (there’s one behind each flap) holding the two halves of the ‘ball’ together.
IMG 4092
Get behind this clip with a mini flat head screwdriver and push through so there is a clear gap. Do two of these and wedge something between the halves to stop it closing back together. Repeat for 3-4 clips and the rest should pull apart.
IMG 4093
Remove the middle… Octopus(?!) looking thing, and pop out the plastic flaps.
IMG 4094
Wash the flaps in washing-up liquid to remove the finger grease/dust and dry with kitchen roll.
Lay out all the flaps shiny (concave) side up on newspaper/ a Bravissimo catalogue.
Tip - Use blue-tac to hold the pieces down - the flow from the spray can may blow them around a bit, and they won’t stick to the newspaper after painting.
Apply 3 coats of the spray, starting with a light coat, and leaving for ~20 mins/until touch-dry between coats.
IMG 4101
TIp - Once fully dry, GENTLY use a nail file to take some of the ‘stickiness’ off the small plastic notches that stick out in the centre channel. This will allow smoother operation of the diffusers. (Optional - not a lot of room)
I left the paint for about half an hour and went over it with a cold hair dryer, then clipped all the flaps back into the casings.
Tip - Gently wiggle each of the flaps back and forward a good few times once popped back in - this will loosen up the movement, taking the ‘stickiness’ off the legs, where they clip into the case.
IMG 4102
Put the ‘ball’ casing back together in reverse order, taking notice of the orientation of the three arms in the centre, in relation to where the frame will fit between the flaps - incorrect positioning will push the Octopus(?!) out of place and may snap one of its legs (I did this first time - superglue = job done).
Pdf page 001
Slide the ‘ball’ back into the outer casing, lining up the notch on the side of the ball with the groove in the casing. Operation may be stiff at first, but will loosen up with a few uses.
IMG 4118
Put back in the car, take it for a drive, and notice the increased performance due to the added red bits.
IMG 4121
IMG 4125
This was very easy to do… I burn my toast and overcook my eggs EVERY SINGLE Saturday morning, and I managed!
Let me know how you get on… And as always, Picture or Didn’t Happen!
Cheers,
Max
Reactions: ukd4v1d, 54V4G3, MikeSel^ and 27 others
Tried taking mine apart a while ago but didn't want to break them, gonna do mine tomorrow thanks for the guide.
Reactions: Max-Robbo
That looks good. I just wish I could get the diffuser vents at all. It would be too much more to wish for colored ones.
Epic write up and amazing looking end results - well done Max !!
Reactions: Scottyg, Max-Robbo and pburv
Thats a " Top Draw" write up. :innocent:... Sorry I couldn't resist... In all seriousness thats a good job. Nice one.
Regds
Jungle
Reactions: Rob2k68, Max-Robbo and pburv
I shall be on it at the weekend Max...
That's a ****** great 'how to'..If it's not in the how to section yet..Then it should be...:friends:
Everyone's going to be driving around in RS's now..lol
Reactions: Rob2k68 and Max-Robbo
Thanks for the comments fellas!
@Mike Feldman you can turn yours from non-slidey to slidey quite easily. Follow the above until you've got all the components separate, and you'll see little support tabs on the 3 arms in the middle of your 'octopus'... These stop the movement - use something small and sharp to cut them off and you're done!
Reactions: Simon L, Daytonapig, richinsoton and 2 others
I know Im very late with this thread but I carried out this mod today and I'm delighted..great write up and pictures to follow when doing it.. I now have go faster red vents..
Reactions: jungle650, pburv, Scottyg and 1 other person
Looking good mate - welcome to the red vent club ! :friends:
Thanks rob, was your vents that I saw that made me ask. Lol..
Has anybody had any joy removing the wing mirror covers, thinking of having mine hydro dipped with carbon
Reactions: pburv, Scottyg and Rob2k68
And maybe the rear diffuser ?..I like to be different :scared2::scared2:
Reactions: Rob2k68
Reactions: pburv
Cheers, couple of questions..are yours genuine carbon replacements or dipped..
Do you think dipped is a good idea?
Also no relation to previous questions but how do you get the little side taps to your name like dsg and carbon black or S3 etc etc
Reactions: pburv and Rob2k68
Mine are genuine from Audi mate. Dipped could work maybe buy one from Ebay to try it on first ?
Think it's easier to do from a computer, can't find the option on my phone - I'll pm you from works computer tomorrow.
Reactions: pburv and As3newbiE
Cheers mate, I'll have a look 1st at the genuine ones,
Reactions: Rob2k68
I'll post some pics of the differences - the carbon weave direction on the replicas is half moon shape on the front where the Audi ones the weave is a straight line from the front over the top, also the step to where the front bezel fits is carbon on the Audi ones. Reps are good for the money tho from what I've seen less than £100z
Would it be possible to remove the chrome trim and paint red like in this photo?
Reactions: A3_Portugal
I performed this mod today. Huge thanks to the OP for the excellent how-to!
I would suggest one addition to the write-up. When assembling the 'octopus' back into the flaps, there is only one way it will fit. I thought there would be 3 ways as there are three clips but that's not the case. The 3 clips and 7 flaps all need to align so make sure you have the only way that will fit together.
It took me about 3 hours in total to do the mod. Anyhoo, here's a few pics of the completed job :)
20170715 190322
20170715 190417
20170715 190427
Reactions: Bittern
Hum..
That painted with a dark blue would be great..
I'll have to check this later!
Thanks!
Reactions: Rolly12
Reactions: Nosnevets
Did you paint the interior trim?
Yeah! I love bringing the body-color paintwork to the interior. I actually wrapped the trim pieces in vinyl before spraying them with Sepang too, so if I ever get tired of it or when I sell, I can just peel them off and have them aluminum again.
Reactions: MattSedg, allanmb and Tom.H
Yeap, just like that!
Can you post a photo of the 4 vents?
I've checked my car and since it is a 8V, the vents are not like that right?
Tough to get a good shot of all four but I took these before I did the trim.
20160726 121015
20160726 121044
20160726 121241
Reactions: Nosnevets and A3_Portugal
I sat in the back seat to get a photo of all 4 in one shot ;-)
How easy is the trim to remove?
The dash trim is super easy, you literally just pull off the small driver's side one. The ones surrounding the dash buttons require you to use "stereo removal keys" to get that bank of buttons out first, then they just pull off as well. The doors are much harder, unfortunately. They require full removal of the door card as they are torx-bolted on from the back or inside of the door card. I still haven't done any of the door trim pieces as I would like to get some grey leather inserts for above the arm rests to match them up with my two-tone leather seats and I would rather do everything all at once.
I have a genuine set ofvRS3 vents for sale £205 posted within UK
PM to buy
Great tutorial! I too have joined the red vent club today! Hard to get good pictures as very sunny but here goes.
Reactions: allanmb and jungle650
looks great, i need to do this.
Reactions: RL
