Craig Kelly
Audi newby
Hi guys hope you're all good, I wonder if anyone can help me out here, my A3 1.8T recently failed it's MOT on emissions - running rich.
I took it to an Audi specialist and they gave me 2 codes and told me to replace the Cat and the pre-cat Lambda sensor.
The original fault codes were:
16514 - oxygen (lambda) sensor B1 S1 P0130 - 35-00 - malfunction in circuit
17511 - Oxygen (lambda) sensor B1 S1 P1103 - 35-00 - performance too low.
I just had the catalytic converter and a new Bosche pre-cat fitted and now I have 4 fault codes, the 1 original fault code + 3 new ones!!!
17511 (same as before)
17513 - O2 Sensor Circuit Heating Circuit (B1-S2) -Short to B+ / or Oxygen (Lambda) Sensor Heating: B1 S2: Heating Circuit Short to Plus : P1105
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High : P1114
17514 - O2 Sensor Circuit (B2-S1) Voltage Too Low - Air Leak / or Oxygen (Lambda) Sensor: B2 S1: Voltage too Low / Air Leak : P1106
I'm losing the will to live with all this! could anyone please tell me what to do next??!!
thanks
thanks
