Particulate Filter help
Usman786
Manchester
Hi guys,
A message came up few days ago saying particulate system fault.
After filling up diesel I drove the car for over 1 hour last night at 3k revs in 4th gear hoping it would regenerate but it never.
Then today it came up with Glow plug light flashing and Engine Management light.
Any ideas what the issue is?
Saturday,30,April,2016,
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: Xxxxxxxxxxxxx License
Plate xxxxx
Mileage: 97964km-60872mi Repair Order: 3 30042016
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V
Mileage: 97964km-60872miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 AL HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6546
Revision: 84H22---
Coding: 02190012030501092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021AL 002011
ROD: EV_ECM16TDI01104L906021AL.rod
VCID: 6FEDA598B6423F4697-803A
3 Faults Found:
5188 - Diesel Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 97956 km
Date: 2016.04.30
Time: 12:47:27
9491 - Oile Pressure Regulating Valve
P164E 00 [047] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97813 km
Date: 2016.04.28
Time: 22:36:35
11523 - No Communications with Control Module for Access/Start Authorization
U100A 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 97813 km
Date: 2016.04.28
Time: 22:36:36
Readiness: 1 1 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 62893000000745
Coding: 12F18AA224280A750177060341CB2548512450806082A4F2004100080608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7BF581C8F23A53E62B-802E
1 Fault Found:
8291 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 94
Mileage: 97813 km
Date: 2016.04.28
Time: 22:43:00
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0040
Revision: 20025000 Serial number: 00000000173826
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008017
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 326B6CEC65F052AEB8-8066
2 Faults Found:
197122 - Temperature Sensor for Left Vent
B1087 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 51
Mileage: 97813 km
Date: 2016.04.28
Time: 22:36:34
197378 - Temperature Sensor for Right Vent
B1088 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 51
Mileage: 97813 km
Date: 2016.04.28
Time: 22:36:34
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011328800971
Coding: 07040842C24100DD03844004B31407A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 79F99BC0F80661F639-802C
Slave 1:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130923 041 0580
Serial number: 131002084812
Coding: 0A47F7
Slave 3:
Subsystem 2 - Part No SW: 8V0 941 531 N HW: 8V0 941 531 N
Component: E1 - LDS MQB H05 0032
Serial number: 18 08 2013 00000332
Subsystem 3 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY132542BZA
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000057991245
Subsystem 5 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20530458
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 56
Mileage: 97813 km
Date: 2016.04.28
Time: 22:40:48
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R03MC6B
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 4B951108E21A2366DB-801E
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 710 13
Component: SideSensor_Df 001 0887
Serial number: 357670000000863DFD00
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 000 710 13
Component: SideSensor_Pf 001 0887
Serial number: 358670000008163DFD02
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 401 710 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502AB11FBEA4E1B$
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 401 710 13
Component: SideSensor_Pr 001 6149
Serial number: 35265029D11FBEA380BX
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 004 15
Component: FrontSensor_D 001 6149
Serial number: 3556502C919EFF5180B/
Coding: 2D2D2D
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 205 15
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A11A91E0283EC
Coding: 2D2D2D
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 402 005 15
Component: PedP_Sensor_P 001 6149
Serial number: 22965029F1A2DCD2C1A/
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 402 005 15
Component: PedP_Sensor_C 001 6149
Serial number: 23065029F1A2DCD221CO
Coding: 2D2D2D
No fault code found.
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 BM HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 03101308491208
Coding: 8408
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 0603E03CB9F81E0E44-8052
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 970 N HW: 8V0 920 970 N
Component: KOMBI H03 2220
Coding: 27850A00228046000100E800100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 479D2D38FE72C706FF-8012
2 Faults Found:
9582599 - Switches in Instrument Panel
B1238 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 51
Mileage: 97813 km
Date: 2016.04.28
Time: 22:37:39
1048578 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Mileage: 97813 km
Date: 2016.04.28
Time: 22:36:34
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1164
Revision: -------- Serial number: 0001159374
Coding: 030100040B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear.rod
VCID: 3E7348DCA1A886CE4C-806A
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Component: E221 - MFL H02 0014
Serial number: 09 05 2015 A0020746
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 8907351403
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 15101301100530
Coding: 00108E204001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 408F3624DB5CF03E3E-8014
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
VCID: 3D714FD0ACAE9DD655-8068
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 15101306070428
Coding: 001086204001040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3F8D35D8A6A28FC647-806A
Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 040 0420
Serial number: A7F01910132541
Coding: 01730301FF00000021111101000A00002F0004460100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_AU37.rod
VCID: 3B7541C8B2BA93E66B-806E
Engine Control Module 2:
Subsystem 1 - Part No SW: 8V0 919 866 B HW: -----------
Component: ECE 2014 --- 0036
Serial number: --------------------
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 603 B HW: 8V0 919 603 B
Component: DU Std H48 0013
Serial number: AUZ8Z9DM700ASA
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000029081300010389
1 Fault Found:
0518 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 51
Mileage: 97813 km
Date: 2016.04.28
Time: 22:36:38
End-------------------------(Elapsed Time: 03:04)--------------------------
Address 01: Engine (04L 906 021 AL)
16:34:52
506 Particle filter; air pressure sensor 1 bank 1; raw value 3 hPa
507 Particle filter; differential pressure sensor 1 bank 1; offset 3 hPa
508 Particle filter; field regeneration lock status-Bit 0 0
509 Particle filter; field regeneration request status-Bit 0 8
510 Particle filter; fuel consumption since last regeneration 50.72 l
511 Particle filter; kilometers since last regeneration 983631 m
512 Particle filter; oil ash volume 0.06 l
513 Particle filter; oil ash volume 26.6 g
514 Particle filter; soot mass calculated 40.47 g
515 Particle filter; soot mass measured 15.62 g
516 Particle filter; time since last regeneration 98273 s
517 Particulate filter ash load limit 80.00 g
16:34:56
Looks like it's blocked, would you mind cutting your VCDS scan down to the relevant Engine section? Saves a bit of scrolling.
No expert, but I found this after a quick google, post 4 seemed to have the answer for this guy who had a lot of errors http://www.mytiguan.com/index.php?/topic/2790-lots-of-fault-codes/
His reply was:
Having no clue what you did or did not do, I can only offer this. Go into each controller that shows an error and clear the codes there. I have had VCDS not clear codes from the autoscan screen. There is no need to disconnect the battery over night, but do ensure it is fully charge before proceeding. Also turn off everything you can in the car before beginning
Maybe try a 20 min journey utilising all the gears and keeping at 2k revs and about in each gear.
Try this and you should realise a regeneration and hopefully it'll clear the "gunk".
If this fails, suggest popping in to the Dealer to get your error codes reset and for them to have a look.
Good Luck.
Good Luck.
Read the second line in the first post.
I did, that's why I typed my reply.
He didn't change the gears.
When this happened to me, I kept driving in the same gear for half an hour each time and it wouldn't clear the fault.
When I went through all the gears, this cleared the fault - and has kept it clear now for about six months and counting.
Just trying to help the Guy try a few things first before he pops back to the Dealer.
