Brakes upgrade (from A4 B7 1.8TQ to A4 DTM 2.0TQ)
aloakos
S3 8P MY2008, Stage1+ 300BHP
Athens
I've just upgraded my brakes from stock 1.8T to A4 DTM 2.0TQ.
The diameter is slightly larger but the thickness is more (new 320X30MM 5/112; PR-1LA, old 312X25 5/112)
IMG 20160412 102623 HDR IMG 20160412 102628 HDR
Also the brake pad surface is 30% more.
The job is very easy and no special tools are needed. The only "catch" is the bleeding of the system, where two man are needed and o bottle of DOT4 fluid.
IMG 20160412 102316 HDR IMG 20160412 111834 IMG 20160412 111840 IMG 20160412 113306 HDR
I used Ferodo DS2500 that have no warning cable so I had to cut old cables and connect them together in order to avoid brake pad warning in inst,cluster.
IMG 20160412 111901
Old brakes
brakes-alex-png.88741
http://www.partsbase.org/audi/audi-...540-floating-caliper-brake-brake-disc-vented/
New brakes
brakes-zakis-png.88742
http://www.partsbase.org/audi/audi-...545-floating-caliper-brake-brake-disc-vented/
I use 17'' wheels from A4 B8 7.5Jx17 ET42 - 8K0601025K
IMG 20160412 112144 HDR IMG 20160412 112138 HDR
Parts Used:
1 4F0615123 brake caliper housing; left 1
1 4F0615124 brake caliper housing; right 1
IMG 20160412 100022 HDR IMG 20160412 100034 IMG 20160412 100027
7 8E0615301AE brake disc (vented); punched; 320X30MM 5/112; PR-1LC 2
IMG 20160412 100347 IMG 20160412 100136
18 bracket; see illustration:; 611-20 2
The improvement is HUGE, especially in high speeds and in mountain roads.
Enjoy
Reactions: Dani_B19, James.c, stu-evans and 1 other person
Just an update.
The brakes I had installed were used so the thickness of used brake pads allowed the wheels to fit.
After renewing the brake pads the wheels wouldn't fit so I had to use a set of 10mm wheel spacers.
Sent from my Redmi 4X using Tapatalk
Get a set of S4 carriers and run 345mm disc the calipers are the same :)
Reactions: aloakos
