Scratch removal sepang blue
Stevie k
When I lifted my Labrador into my boot this am his Claw marked my bumper leaving a six inch scratch what's best way to polish out also is sepang blue a soft paint as his claw hardly touched it have had the car 3 weeks
Is the scratch deep enough to catch your finger nail in? If not then a machine polisher with a compound will get it out.
If your nail catches, then you'll need to look at a proper touch up kit / respray
Reactions: Stevie k
No I don't thinks it's deep enough so I will try a compound first
start with seeing if your nail catches on it - as stated above.
if not, start with a fine polish, and work your way more corse, using a finishing pad - till its removed and then back to fine again.
if it catches, use a cutting pad and a corse polish, working your way fine, this will remove some of it. then get it touched up.
OR
you confident to take wet / dry to it?
do the above and then wash the area, what ever is left, spray 1000grit and lightly, very lightly rub over the top of it. every 2/3 rubs, wipe it down with a wet cloth, flip the paper, spray it and go again, until its gone.
then polish it with a finishing pad to bring it back up.
IF its down do the actual base coat or deeper, i.e to the panel, similar principles apply but more work needed.
Reactions: OliS3
