Hello All,
Am new to the forum and just wanting some advice if possible.
Have a A3 8P 2004 TFSI. 120000 miles
When fitting a new timing chain last year noticed this(see pics) Basically dry cam lobe on cylinder1(I think?) Inlet Cam.
Is this common. What would be your thoughts. Would you replace the Inlet Cam only and try to clear out the oil passages or would you think there was more underlying issue?
Have read previously else where that the rev A cams are prone to wear, but it seems it is due to low or no oil flow.
Is there a better replacement kit or would you just fit an OEM Inlet Cam only and carriers...?
Any help would be appreciated
Kind Regards
Glen
Kind Regards
Glen
