Changing the Head Concert II
Gazanfer Smith
Hi,
I have an audi a3 2.0T Quattro and I wanted to change my stereo from a Head Concert II to a diffrent single Din stereo. I have no Bose sound system and No steering controls on the wheel.
My problem is that I'm clueless as to what i would need to change it and if the other stereo would be just a plug and play.
So far the only thing i plan to buy with a stereo is a fitting kit
https://www.dynamicsounds.co.uk/aud...gle-din-car-cd-stereo-fascia-fitting-kit.html
Would i need anything else?
Thanks in advance
Halfords have correct cable just ask them and tell them what it's for and they'll point it out for it
Hi again, I finally gathered the courage today to do my stereo and I followed your steps however ended up with the stereo not powering on. I wanted to ask what color wire I have to cut to tie the ignition live in.
I have provided pictures of the radio book and wiring
Thank you in advance
Hard to see why it would work if followed to the t. There's two wires that control power. A yellow and a red. Have you swapped them over and tried?
If I recall the yellow one is what that gets cut to connect to ignition live...just make sure you don't cut the car harness only the harness you bought...
Hope this helps
