Oil Catch Can on Audi TT RS
Phenyl85
Dear all,
Recently I fitted an oil catch can on my 2010 Audi TT RS.
Just wanted to share this for anyone interested in also putting a catch can in their car.
IMAG0812
This is the Mishimoto Compact baffled oil catch can (bought on e-Bay).
Mishimoto compact baffled oil catch can 2 port 29
Here you can see all the parts and the brass filter which separates the oil and air, the baffles and the bottom plate which will keep the oil inside the can.
IMAG0846
This is the hose of the front cam cover.
IMAG1071
After heating that tube a little bit the connectors can be pulled out (this tube costs €275,- from the dealer!).
IMAG0884
This is the heat isolated hose going towards the turbo which will be modified.
IMAG0921
After loosening two Torx 30 this will come off.
IMAG0927
Here the heat isolation is stripped down a bit to heat that connector too, it will also come off with heat.
IMAG0951
Here you see that connector (21mm outer diameter).
IMAG0947
This is the catch can with the drain hose attached to it including a little valve. The bigger hose is the one that also is needed to fit the catch can.
IMAG0946
The valve
IMAG0944
Overview of the situation.
IMAG0950
Close-up of the oil and gasoline resistant hose (21mm inner diameter)
IMAG0948
This is to show you where this hose will be placed.
IMAG1037
Heat isolation is needed because of the turbo.
IMAG0942
Here you can see two screws where the catch can will be attached to with a bracket.
IMAG1041
Bracket installed
IMAG1044
Catch can with drain hose
IMAG1047
Catch can installed
IMAG1046
Overview
IMAG1052
Drain possibilty because of valve underneath the car.
IMAG1085
By using the original connectors a hose was attached (oil and gasoline resistant) with a plug inserted.
IMAG11301
Another close-up after covering up the brass connectors with some black tape.
IMAG11331
Another close-up.
I hope you enjoyed the write up, if you have any comments or questions just ask.
Mark.
