How To: Remove rear door card
Rhyso
Merthyr Tydfil, United Kingdom
I retrofitted puddle and warning lights to the rear door cards and found that there was very little info on the net about how to remove the rear door cards so I took some pics which I hope everyone will find useful :)
All you need is a Torx 20 bit, a flat blade or trim removal tool and some brute force!!
Top tip is to wind the window down to give you easier access when removing the door card
First you need to remove the aluminium (or whatever colour) trim by the door handle using the flat blade to reveal the two hidden screws
Back of removed trim so you can see the clips
Then undo the screw below the door handle
Next is to get the flat blade at the bottom and start levering towards you. Once you can get your hands in simppy work your way around to the top. Don't be afraid to use a bit of brute force
Pic of the back of the door card showing the various clips
Then pull the door car up and start unclipping the plugs and door handle
Top is the speaker cable
Unclip the Yellow clip for the door handle cable
Finally undo the connector that goes into the door control module at the bottom (bottom of the pic)
Fitting is reversal of removal!! Clip the plugs and door handle cable back in
Then lift the door card back onto the lip at the top; having the window down as far is goes makes this step a little easier!
Put the screws in
Tap the clips back into place
Job done
Hope this helps :)
Rhys
Reactions: L111 FAD, TheStigOnline, GavG and 2 others
Thanks Rhys. I Wil make this a sticky.
Reactions: Rhyso
Put the screws in
Job done
Hope this helps :)
Rhys
hello there
can you share how and where did you connect the wire for puddle and worning light t have also audi a6 c7 4g without lights in the back doors
thanks buy the way nice topic
Reactions: Jakes2514
hello rhyso
i would like to have some info about how and where you connect the wires foe the for puddle and worning light
i read it already but i cant figure out where you connect the wires .i have foot light front and back puddle and warning front but not in the back
Do you have ready made looms or just wires??
The looms simply plug into the wiring loom that runs to the door module. If you have wires then I cannot help you as I bought looms that simply plug into the loom going to the door module
My warning lights in the front piggybacked off the bottom puddle lights
My puddle and warning lights in the rear doors used one loom which connected into the door module. It's the bottom on the module as per my last pic in the first post :)
i have this one
  • lights.pdf
