Have to say I do like the Xenons....but jeez even just changing the bulbs is hard as Audi very kindly gave 0.3mm of slack on the wire connector. Then the ballast pack job...I've still got the backache I think! hahahah
Newer simple better dual diversity FM/AM antenna, not the older ZF complex diversity kind too, I should add lol - much easier to update if you still value FM radio that is. There's no solution for good radio reception on the pre-2007s, since with ZF you are only ever using one of three ariels in the rear windscreens, even with an amplifier and even with the best aftermarkets.the other change for that year was from ISO to Quadlock and Concert and Symphony II+ (no cassette at last, lol) both double din now
I know Matt the B7s are crazy - you can take off the headlights on a B6 without removing the whole blinking bumper, and you always cut yourself just changing the main beams. Those pesky sidelights too (which are an MOT failure if down) jeez!Have to say I do like the Xenons....but jeez even just changing the bulbs is hard as Audi very kindly gave 0.3mm of slack on the wire connector. Then the ballast pack job...I've still got the backache I think! hahahah
Another box ticked .Old g28 sensor is replaced, what a headache to get to the bolt. If any of you have to do it remove the coolant bottle and remove the intake support nearest to the bulkhead, than from underneath, remove the last bolt so you can get to the bolt from the g28 sensor. Stick your hand in from the gearbox side and you'll soon have the 10mm bolt out.
It sits right above the middle of the sensor, just make sure you use a 3/8 or 1/4 deep socket on a ratchet. That did the trick on mine.
Took me longer than I expected, because I had to findout how to get to the bolt since I couldn't see it at all so you all know
On the OS that was one that siezed Matt, it took some work, I used some of this: https://www.machinemart.co.uk/p/clarke-cht659-long-screwdriver-set-ts-star/ . In a perfect world, along with a new bumper/grill it could do with the complete new Audi fitting kit - but at £166 it'll do. All in all though, may not be the finest around and only a modest example in the B7 line-up, but she's a long way today, from how we found each other 8 years ago, and she runs and now sees like new.How did you get on with the hidden torx...the one through the access hole in the wing?
Thanks bud! They do make the whole car look much newer and mainly they are very practical and safer performing as they should too IMV. The old lights although not too bad, were diffusing and scattering light all over due to the fine stone chips that I could never buff out properly. Off they looked clear but on you could hardly see the bulbs.@B7Tourer looks good that![]()
Ah could be, I don't think I've ever tried it...will report backIsn't it simply + and - on the display, Matt? Same as used to change time and date?
Yeah that's another great option I don't have, lol. I coded mine for Nordic drls, so they are always on, I only have to remember to switch on then, when I can no longer see the dials, good for tunnels too. I'm surprised Audi didn't strip out the options on base S-Lines for the 'sporty' driver even more... you know? No A/C and no ICE, ha ha. Does anyone know the coding to illuminate dipped beam green in the dash warning? I know it is there, just as the main beam blue one is.the only time i actually touch the switch is when i want to make sure there is nothing draining power.
Thanks bud! I'll have a look. Happy to report the new HLs are definitely RHD, after having them checked, and the condensation seems to have disappeared - I think I'm just not used to them being so clear. I bought these (below) for when she next rocks the continent, which is soon to see my grown up daughters. I so hate those Goddamned Eurolites that just block light. These bend it like the Audi items I mentioned before, hard to get now:'m not sure if it's hidden in module 17.. either 07 or long coding... I didn't have to mess with my cluster so I didn't have to use the coding part of the cluster.
