Could do a duel caliper rear set up
You only need to do the S4 rear upgrade, that the best one for the rear; it complements the 18z on the front perfectly.Could do a duel caliper rear set up
I'm sourcing a set at the moment for the allroad.![]()
Some 20” diamond cut mtm bi motos on flea bay at the min ,very expensive but very cool
There’s no pockets in coffins
Indeedy.Was behind a b8 saloon badged up as a s4 ,he’d done everything but bought the right rear valance ,twin duel piped but he’d obviously just jig sawed the right hand side out ..badly ,pipes stuck out further on a completely different height
Why bother ,the people that your fooling aren’t worth fooling and it just looks chavy to those that know ,spend the money on maintaining a stock car that’ll retain more value
Indeedy.
Its hard to get that special look that is right but very easy to make a right hash of it and look rubbish.
But hey, each to there own, if it works for him then albeit.Was behind a b8 saloon badged up as a s4 ,he’d done everything but bought the right rear valance ,twin duel piped but he’d obviously just jig sawed the right hand side out ..badly ,pipes stuck out further on a completely different height
LOL ofcourse i forgot you were working there too and was part of that conversation...That's not true; anywhere.
100%!Was behind a b8 saloon badged up as a s4 ,he’d done everything but bought the right rear valance ,twin duel piped but he’d obviously just jig sawed the right hand side out ..badly ,pipes stuck out further on a completely different height
Nonetheless Northpole... what I said is and was the case, particularly about standard vs higher powered models having different hex keys... whatever your mates told you. Believe me I could write a thesis about the VAG PD 2.0TDI blinking oil pumps and why driving any oil pump from a balance shaft was the daftest of ideas in the first place, lol. It would be very boring but I would have checked my facts, beforehand. If however you can point to any VAG bulletin proving otherwise I stand to be corrected.LOL ofcourse i forgot you were working there too and was part of that conversation...
100%! My brother had a very convincing M5 clone once, quads and all, that was really a bog standard 520D. You could never escape the clatter of that 2 litre oil burner, no matter the remap.Was behind a b8 saloon badged up as a s4 ,he’d done everything but bought the right rear valance ,twin duel piped but he’d obviously just jig sawed the right hand side out ..badly ,pipes stuck out further on a completely different height
Yes this is why i pointed to people breaking mk1 q7's and mk1 Touareg's both of them have the 18z setup and somehow people seem to forget that both these cars have them on the lower powered diesel engines ( mk1 q7 the 3.0 tdi and the mk1 Touareg the 2.5 tdi) if you are lucky enough you can take the complete set at a decent enough price... or even less if they just want the car out of the way. It does mean in most cases you'll have to bring your own tools, but in my experiene that way you usually get a full set that isn't siezed, i'd still give them a refurb though.I’m finding lots of front and rears ,q7 ,cayenne etc or rears only for both ,.seems folk buy the f&r and try to sell the rears
Same reason for there being loads of pairs of rear Porsche lobster claws 11j for sale
that looks fine just the way it is... but hey wheels are like shoes sometimes you just want a fresher looking pair in a different style.
I kinda like the contrasting areas, which makes it stand out a bit from the rest, there was a factory option for it to be colour coded but mine is two tone.that looks fine just the way it is... but hey wheels are like shoes sometimes you just want a fresher looking pair in a different style.
Just think how sick the allroad models would look if they didn't have that contrasting colour on the added bodykit.... I'd just do the greyish bit the alluminium coloured bits i'd leave alone... it would make it look more blended in and a bit more like a widebody... I so wished i could find a project one at a decent price just to do that
Not exactly what I had planned
Booked in for alignment,that ended abruptly when they discovered my tie rod end was seized so spent time correcting that
Thought I’d ease and unseize a few other bits while I under there for future projects
Also removed sill trims and started to prep the jack points as I have a mate coming round to sure up my jacking points next week
Seriously considering mud guards now![]()
That's slightly alarming JamsmooAlso removed sill trims and started to prep the jack points as I have a mate coming round to sure up my jacking points next week
My fronts were fine for tracking but the rear eccentrics were not; very common. I've since replaced all those. If you can best to get a full 4 wheel alignment done since the rears being off affect the fronts too.Booked in for alignment,that ended abruptly when they discovered my tie rod end was seized so spent time correcting that
That's slightly alarming JamsmooLast time mine were partially off was about 2/3 years ago when I had new wings fitted; both sides looked good in that department but when I recently Lanoguarded the underneath, I did have to treat the jacking point seams, that were showing some small signs of corrosion. What is your mate doing to prep your jacking points? How did you remove the covers? My brother who had then a body shop did the work at that time. I'm not sure mudguards will help much, since they just protect the plastic really. Mud and water get in through the inner wings. They add to drag and noise too and mud can get behind them corroding the wing edges.
I’m leaving it in his capable hands ,he welds plant machinery on site ,digger boom arms etc
I’ve asked for 25x3-5mm flat bar approx 8” stitched centrally across the jack points
My nearside front is weak after the car slipped on a jack and folded it in
I’ve got an mot coming up and while it wasn’t an issue last year I’m aware it hasn’t got any better the times it’s been jacked up this last year
I usually use a more structural jacking point further under with my low profile trolley jack but that’s not an option road side etc ,it’s a 4 tonne beast so isn’t kept in the car lol
The trims are held by many t20 screws from underneath,each wheel arch and beneath some removable trim along the door shuts
