This thing is a work of art!Been out in the garage getting ready to fit the Hybrid KO3 330BHP Hybrid Turbocharger K03 5303-970-0106 STAGE 3
turbo over the weekend, I'll also refit the decat pipe I was using, may as well utilize it.
Double checking I have all the bits, there is nothing worse than starting a job only to find out when it comes to refit that a vital small part is missing.
Here you go Matt.Just going back to the plugs, I've seen it in the Subaru world about "hotter" and "colder" plugs, but what does this mean?
Thanks RobHere you go Matt.
A definitive answer from the experts.
Understanding Spark Plug Heat Range
One of the most misunderstood aspects of spark plugs – is the heat range. One misconception is that the heat range is related to the spark temperature or intensity. Another common misconception is that the spark plug is designed as a heat sink to “remove” heat from the combustion chamber. These ideas are both false. The spark plug is heated during combustion and must dissipate that heat to the cylinder head at a certain rate to avoid overheating the ceramic firing end. The spark plug heat range only indicates the rate that the spark plug dissipates its firing end heat to the engine.
A hotter heat range spark plug has an insulator design with a longer heat flow path to the metal shell of the plug. As a result, more heat stays in the ceramic firing end and less is dissipated to the engine. A colder heat range spark plug has an insulator design with a shorter heat flow path to the metal shell of the plug. As a result, less heat stays in the ceramic firing end and more is dissipated to the engine. For a spark plug to function properly, it must have a tip temperature high enough to burn off carbon deposits (self-cleaning) and avoid fouling, while remaining low enough to avoid overheating the ceramic firing end and pre-ignition.
For most vehicles, the factory recommended heat range is sufficient; however, on some modified or special-use engines, alternative heat ranges may be necessary. Often hotter heat ranges have been used to address a fuel delivery or oil consumption problem. Installing a hotter heat range plug will reduce the pre-ignition safety margin, so it is better to correct the mechanical or tuning issue instead of changing the plug heat range
when I sell the old bus Matt you can have mine, might be a while though.Any carbon fibre trim inside?
Are they definitely S4 front and not just the larger special edition disks/calipers?yeah I did check the MOT history and to be fair the previous owner did keep ontop to repair the lot so it passed but somehow the new owner ( the one that is now selling it) drove it home and it conked out... it still turns over... but the oil everywhere and the fact that he has several performance cars on his drive ( ford focus st, subaru sti eagle eye and an m5 e90 saloon, all of which are modified) kinda tells me that the engine is toast....
but as i said S4 brakes and slotted disks alround (+ braided brake lines), 19 inch wheels with good tires, colour cluster, s-line leather interior, nice new coilovers (2 months old i've seen the receipt and the keys to set them), new led rear light clusters, auto hatch opening struts, and basically the paint is almost prestine except for one little scratch on the OS rear quarter next to the door opening... other than that the bodywork is flawless. and with it being a 2.0t it has the dual exhaust already... plus it has a removable towhook with it's electrics still on it ( mine was taken off and sold off by one of the previous owners as it's on the option list but nowhere to be found)
Anyways.. i need to convince the wife that it's a good deal even if i just use it as a donor car... which is what probably will happen.
the cummalative parts i just mentioned used will set me back at least another 1200 to 1500 pounds... the asking price is 500 for a non running manual 2.0tfsi 200bhp avant ( note it's in the same colour as mine and has tinted windows already)
so it's a bargain parts wise already... i think i've made up my mind by actually putting the numbers down... I'm getting it.
ps I can store it on a private parking spot at my daughters until i'm done ripping the parts off so no exra costs dvla or tax wise.
Is yours the fishtail silver trim or brushed aluminum?Any carbon fibre trim inside?
when I sell the old bus Matt you can have mine, might be a while though.![]()
I have silver fishtail which to be fair I quite like as it's nice and bright and breaks up the black interior a bit.I have the brushed aluminum if that's any use for you Matt, not as nice as the carbon though.
Nothing special just simple 19" versions you mostly see on the mk1 Q7 s-line 3.0 tdi. But look better than I thought they would up close and personal.what alloys on it?
Is this literally just an OBDII plug you plug into the car and then plug the cable into the laptop...is that it? Is there also a disc you need to download onto the laptop?ordered myself a new VCDS cable as my old one has gone missing... quite sure it was in the car but it dissapeared... now i could've gone for OBDeleven but i prefer the extra options VCDS gives... since i like to retrofit stuff.
are you a member of wheelwhores? if not you might want to consider it wih your yearly wheel swaps lol... I was on there years ago but stopped going on there as it's an expensive addiction... even when you can get them at a discount 9 out of 10 times you need new tires for a set, apart from that i always want a matching spare wheel... so i used to ed up with at leat 5 wheels ( sometimes 6, as I had a set of staggered deep dished 3 piece wheels, 8J fronts and 9J rears) once i sold those off i went back to running only oem alloy wheels, all with the same specifications to make life easier. also i rather have the car sitting square on all corners instead of having to mess with the geometry of the car, it makes the tires last longer, ut than again i don't go to track days anymore. So there is no need to mess with the carfully calculated geometry settings done by the manufacturer for my daily rides.I seem to change my alloys annually now.
