Are they OEM ?The correct S5 discs have just arrived, will fit later.
maybe even cheaper than what they are now, but retaining the same quality and product specs... I know i want everything as cheap as possible.... but wouldn't you agree with that?what else could one want.![]()
Have you checked the wheel bearing.Nope wobble is still apparent , but no surprise.
Can only be the steering rack now.
Adjust the rack, not sure mine is adjustable, do you have a semi electronic rack?What I have noticed, and it would point more towards the rack, is that the problem is worse since I had a go to adjust the free play a week ago.
I nipped it up, which didn't do anything so I backed it off again, Whether that backing off of the adjuster has made it worse now seems very possible.
Nope, I had these new ones but the old ones were almost new and in good condition, put them on just to see how they ran, not bad but not as flat as they looked so opted to fit the new ones.wait, what? you didn't replace the pads at the same time? ( you know it could potentially warp the new disks) a well you are doing it now... just wait next time until you got the disks and pads at the same time so you only have to take the lot apart once. also a great time to address the state of the calipers ( only if they were just painted)
yep , I've been around brakes long enough to know the do's and don't and what may just be servicible.good thing you changed hem by the looks of the old disks these used pads ( if they ran in right) could potentially warp the disks. You replaced them so the potential problem is avoided.
Well I didn't no that.All the 2.0tfsi special eds have servotronic and as such all have the free play adjustable function.
It's not adjusting the rack operation as such , it's reducing the free play in the rack when not under pressure.
I changed the hyd fluid three years ago and again a few months ago when I drained down the PAS to remove the engine.when was the last time you replaced the power steering fluid ? if you can't remember maybe a fluid refresh will do the trick as i doubt it's got anything to do with the steeringrack itself but the fluids? let me say it this wa, the vectra c has an electrical powersteering rack that is partly mechanical ( just like ours) when i had some steering wobble and all the other things where replaced i almost replaced the steeringrack... than i realised, i didn't do the powersteering fluid replcement yet... I went to remove the lot and what came out was well and truly past it's best. it had the same black particles in it as brakefluid does once it gets old... once i made sure i had all of it out ( used a fluid transferpump to drain it) i than ran half a bottle of new fluid through it, started the car and moved the steering wheel from side to side to get the last of the dirt loose and into the oil.. i removed that than replaced the lot with new.. the wobble was gone. Not long after the rack sprung a leak though so those black particals in it where from broken seals... had those replaced as i couldn't be ***** to pull the rack and change the seals. On a vectra-c the seals of the rack can be replaced in situ, if you have the comfort of a bridge, so took it to one of my mates that works in a garage and he sorted that out for me. i did part with more money than it would've cost me if i diy-ed, but it took tthem less than an hour... DIY without a bridge, would've taken a lot longer.
oww changing coilpacks and not the plugs is false economy... if they are old the new upgraded ones will ware the plugs out super quick... and if you upgrade you either get colder plugs or oem plugs. completely up to you. APR's are good shout, but as i said i'd go R8 oem manufacturer since the prices are not far off from one another for a set of 4.
