Modded my headlight switch using the Golf MK5/6 brushed aluminum look dial.
583021C1 A4EA 4D83 9C93 0BDA407C0EFA
Reactions: tr7, Rob Avant, Charlie Farley and 2 others
How did you do this?
Bought a switch from breakers
471FF73E 059F 4EEE 9979 073724A7104F
Then removed the dial from this switch, removed my dial added a suitable washer held by a smidge of super glue over the centre shaft to space it from the rotary shaft, then apply 2 blobs of super glue to either side of the dial shaft then put it onto the rotary shaft. Getting the dials off is the tricky part if i did it again id probably do a better job as i broke mine but fixed it with some plastic welding and the spring loaded pins from the breaker switch lol
it works and looks the part which is main thing just no release function so if you wanna remove it its done by the fuse panel access as if the switch release is broken.
Reactions: Charlie Farley
Next im doing all the window switches to the B8 ones and also the mirror switch
FEE1D66C 047A 4017 A4D0 A12D6251D54B
Today the new Meyle header tank and cap arrived, revamped fbsw trims arrived too, just waiting on the replacement heater matrix on monday.
piccy of the trims though.
IMG 4313
make a change from silver, and when fitted with switches etc back on should look ok, well i like it.:thumbs up:
Reactions: Rob Avant, Jamsmoo and Fully
As promised, here’s my first attempt at the forged carbon skinning on a test piece. I’m pretty happy with the effect with only top coat epoxy - will be wet and dried back to flat through the various grits and then lacquered, either Matt or glossy.
Reactions: tr7 and Charlie Farley
what sort of final thickness are you expecting to see with it?
Reactions: Bobbytea
On the edges, maybe 0.5mm or less. But if you base coat with black you can get away with less around buttons etc.
This is a test piece and I’ll try Matt lacquer and gloss side by side to see the effect difference.
I’m doing a heater vent for the R26 next I’ll send some images when that’s done. Just gotta wait on curing times - no point in rushing it!
Sex on wheels is that love her lol.
Reactions: Jamsmoo, Bobbytea and Charlie Farley
Almost forgot, welcome to the club.:yahoo:
Thanks love the colour. Also whilst I’m here does anyone know what this second pipe does and can I just use a straight flow air intake pipe for induction kit?
After a cheeky little Bay purchase and it arriving today, i started a job that i assumed was going to be pretty easy.
So i it began like this.
I thought the pedal covers were going to pull off with a little bit of a tug here and there, but after what must be 15 years they weren't budging.
I then used a heat gun to try and soften the rubber, which it did but they still stayed put.
Out came the stanley knife and off they came.
The foot rest was easy, just a screw then slide up and reverse to put new one back on.
The brake and clutch covers went on quite quickly after a bit of heat, but the accelerator was being stubborn even with heat, eventually got it on with a sliver of washing up liquid.
In the end i got there but was a bit slower than expected and ended up like this.
I know it needs a clean :whistle2:
Reactions: Rob Avant and Ryan83
Looks good, im fitted a set before Christmas and im chuffed with them, i must have been lucky too as mine weren't too bad to fit either. Happy days
Reactions: Fully
I’m looking at doing this soon such a nice upgrade to the car Can I ask where abouts you purchased it from as I can only find one place that does the surround and wiring
Best upgrade you can do getting rid of the stock audio system… Give these guys a call, they can supply all the steering wheel adapters, surrounds and hardware. Been using them for years, always good advice, will post all over the UK and open to doing deals too
Reactions: Sidrick and Charlie Farley
Spent a couple of hours this afternoon doing some more upgrades to the old bus. Finally got round to fitting the B8s allround which was a nice easy job thanks to the preventative maintenance to the front pinch bolts. Took me around 2.5hrs including a burger king dinner break which wasn't too bad at all.
20220122 122132
20220122 122125
20220122 122139
So far I've not felt any substantial improvements in the Bilsteins, but i have only trundled home from work, i will give it a spirited run tomorrow and see how they perform.
Also swapped the 034 engine mounts for some OE replacement Febi ones. Thankfully order is restored in the cabin and its now a nice pleasant place to be.
All in all a nice bit of improvement.
Alex
Reactions: tr7, Stu_b7, Ricky Burrows and 2 others
View attachment 248880View attachment 248881
Alex
Are you still running the OE rear springs?
So far Rob yes. I don't think i can manage going lower for logistical reasons, plus im happy with the ride height.
You'll notice the improved damping etc over the OE units once you get some miles covered on differing road surfaces.:icon thumright:
I think the OE springs will spoil some of the advantages of the Bilsteins though, the OE springs are a bit on the stiff side, well mine were very stiff compared to the H&R prior and KW's fitted now.
You'll have to do some miles to get a full feeling for the setup.
let us know how you find them.:yes:
So far I've only covered a 7 miles steady run home from work so its not a fair test for them. As you say I'll get some miles on them and see how they go. I might slip the springs in at some point and see how i get on, but thats a job for another day. The mounts made the biggest difference!
I bet you really noticed going back to the OE mounts, the performance ones are good for performance but do nothing for daily driving /comfort.
Reactions: AvantAlexB7
Picked my grille up from the painters yesterday stuck it on this morning,still undecided on the black rings may go back to chrome
Got a spare sline grille and frame ,will be putting in classifieds if anyone’s interested
Reactions: tr7
Its been the first time out for me in my Avant for over a week due to Covid isolation and the first things that immediately struck me where the vibrations from the engine mounts and also the rev hanging issue seems to have snuck up on me again, which is annoying. Going to swap the aftermarket clutch switch i fitted a couple of years back for a genuine item and go from there. Hopefully its just a faulty cheap part at fault.
There's a Superseded Part number now Alex, don't buy the original part number
I'll take a look at my invoice and see if I can get it.
Should start with an S if I remember correctly
Cheers fella that would be perfect. Am i right in thinking there is 2 switches? I only replaced the 1 last time
Reactions: tr7
There is more than one switch up and under there but fairly sure the other is for the brake pedal
here's the details. Old switch is white and black plastic. New part is all dark/blue-ish?
Photo 2022 01 25 005707
Photo 2022 01 25 005714
Today i fitted a coin/card tray in the dash instead of 2 blanks and an airbag light.
Also replaced my 17" alloys with a set of 19" from an S5.
Reactions: Rob Avant, Jamsmoo, tr7 and 1 other person
Oooo perfect colour and decal combo, very nice mate.
Cheers fella, i was thinking of going yellow but went for an Audi ceramic theme instead with similar style decals. I will taking them back off at some point in the future and getting them professionally refurbed i think. The powdercoating job was a bit poor and is chipping and i have a weepy n/s piston seal too, and tbh i haven't got the time to sort it myself.
My coin tray is one of my favourite features :)
Yeah i remember you saying about the Audi ceramic grey, looks spot on mate, like the rest of your car very oem+ :icon thumright:
Where did you get your decals from Alex and did you do anything extra to keep them on.
Got 18Z i need to repaint and get a few bits for before i fit them.
Just ebay for the decals if i remember correctly, and no just stook them on and they've been fine so far
Reactions: Fully
Thought id replace the clutch switch again as i thought the non gen one i fitted 2or 3 years ago was acting up. I ordered and fitted a genuine replacement from tps, only to find it made the car 10x worse. Rung TPS to get it exchanged as it must be a faulty part and they want me to take it to a dealer and let them diagnose the part as being faulty and claim on the parts warranty for a replacement. If Audi say the part is fine i then have to foot the dealers diagnostic fee!
Anyhoo, refitted the old switch and flushed the £24 i spent on the genuine item down the swanny, so may look at buying another cheapo one at some point.
Very disappointing state of affairs with TPS at the moment unfortunately.
  • Angry
Reactions: Fully
