PARK DISPLAY ON MMI A1
vw754
vorsprung Durch Technik
U.K
Hi i tried to activate the function on my sisters A1 1.4 tsi....think thats it........its got factory sat nav,have vcds but couldnt get it to work any ideas? its a 2011 car with rear parking sensors...only bleeps at the moment
i tried this but still a no go
n the parking aid control unit gives you the option of the Audi A1 8X to activate the visual display of the parking aid via the MMI, even if only the 'small' is installed for rear parking aid.
[Activation of Audi Parking System]
Select STG 10 (parking aid)
STG access authorization - Select function 16
Access Code 71679
STG coding -> Seçim function 07
Byte 0
Bit 2-3 (08 visual display active (BAP NEW) selection)
STG adjustment -> function 10
Select "Visual display for park assist"
New Value: OPS Display
The following code is to be applied:
  1. Select STG 10 (parking aid)
  2. STG access authorization - Select function 16
  3. Enter access code 71679
  4. STG coding -> Select function 07
  5. Select Byte 0
  6. Bit 3 Enable
    (08 visual representation active (BAP NEW) Select)
  7. MMI reset
    (press and hold down the Return key -1- (Back), the confirmation button -2-, -3- and the scroll key at the same time. The MMI then goes down and restarts. Takes about 60 seconds)
Alternatively, should active Bit 3 not function display
  1. Select Byte 0
  2. Bit 2 enable
    (04 visual representation active (BAP ALT) Select)
  3. Disable Bit 3
