Difference between these two climate controls?
ABS2788
Looking at a new climate control upgrade and seen these two on eBay, both look the same but slightly different part numbers - can anyone confirm if there are any differences?
8p0820043 BG and 8p0820043 BM
they seem to cater for the same PR codes (4A0 & 9AK) so I don't think theres any difference.
one heated, one not? only guessing :)
If your doing an upgrade why don't you do the Q3 control panel? looks fantastic in an 8P3 with white backlit LCDs on the speedo
They're both for non heated seats, PR code 4A0.
A Q3 heater control panel in an A3 8P??? I've never seen this!
I have since looked and wonder if this can be done with heated seats, as the Q3 control panel has a push button for the seats rather than the roller wheel???
My car is a '57 plate. Is this modification possible or does it have to be post '08 cars, do you know??
I've seen a clip on YouTube with the q3 control someone in America I believe. Not sure what year car it is but I assumed it was before 2009 because of the steering wheel. Mines a 56 plate and non heated seats. This is part of my double din conversion
I have it in mine, the heater system was different between the 2004-2008 and 2009 onwards cars
If you're doing the double din conversion you need a control panel from 2004-2008 as you've linked the 09 onwards one.
I was going for the chrome switches in red led display so I believe that's like 2009 plus. I presumed it would work, apart from the AC function but I don't have ac at present and don't ever use it so wasn't bothered about it? Can you clarify
Is your car 2004-2008? You can change the buttons on the 04-08 climate but you can't fit the 09 onwards control unit as the heater system is different and it won't work.
You can just trim your unit down to fit the new position as most people do. Saves buying another climate control panel.
Yeh it's 2004-2008. I just read on when @Ash187 did his upgrade, I'm sure he said it works apart from the AC so I understood he changed the buttons in the end
just read this thread and I'm a bit lost on what you guys are trying to do?
if your car is pre 2007 and you want the newer climate control only thing you can do is change the knobs like this: http://www.audi-sport.net/xf/threads/how-to-facelift-chome-climate-control-module-switches.146018/
from end of 2007 (57 plate) onwards some cars were able to just swap a climate control panel straight over from the facelift and it all worked. not guaranteed though... worth a try. best way to tell if it works is plug it in and press the auto button and see if the air actually comes through the vents or if you can just hear the whooshing noise behind the dash.
for the Q3 climate panel to work your car needs to be a facelift (2009 onwards)
I'm confused slightly as well because mine is a 56 plate and reading your thread to where you swapped the chrome knobs across, you did mention that it did power on but when you turned the a/c on it didn't blow any air hence why you turned switched the buttons over. Would it not swap over on mine considering I do not have a/c anyways and would not use it regardless?
How do you not have a/c but yet have a climate control???
It's not air condition related, the motor flaps are the problem. The old units control 2 flaps where as the new one only control 1 flap so it doesn't let the air into the cabin
Oh right okay, I guess it maybe attempting to switch buttons or I might leave it and either trim or source the 2007 climate control with the already trimmed edges
Ive got a 61 plate but its got the standard ac unit in with 3 knobs and 3 buttons (no digital display) and Ive already done a leather seat upgrade which are heated... can I upgrade my unit to support the heated seats?
Yes you can. You just need to find a climate control looking like the one you have today, just including the heated seats buttons. So if you have chrome today, you need new one with chrome, etc.
You of course also need a harness. To connect between the seats and the clinate control.
