Cheapest option is to tweak a bit of torque out of that peak. You aren't going to miss it and it could mean you won't need a new clutch. The longer you leave it and the more it slips the less chance you have of fixing it with the clutch you have.
It does seem to be near the limit of the set up as I haven't put anything in mine yet I'm going for plenty of scope ,frankly I'm amazed my standard clutch is still aliveYes maybe, but from what I can gather this is a pretty unusual situation, most people are fine with the setup for 2+.
Can't see it lasting much longer it I'll take it while it isExcellent, long may it last and as S3Alex said the spec is good option too![]()
You can't compare Ecotunes Dyno with a Dyno Dynamics, the former reads significantly higher. At circa 300bhp, Ecotune reads 20bhp higher than a Dyno Dynamics. On Dyno Dynamics, Revo Stage 2+ cars make 330bhp, APR Stage 2+ 350bhp. I have run several on my own Dyno.
Rick
Yeah possibly gonna go for a custom tune when I get my clutchJust thought I'd add this to this thread as it's interesting information, all figures on the same dyno is not what you usually see so is helpful information.
Could be the reason revo 2+ people don't have any issues with the clutch and APR 2+ people are having issues.
Depends a lot of people don't like the noise from a smfJust a little side note, People that have uprated clutch's, Is it not worth going SMF when you have the gearbox out..?
I have no issues which the Sachs units, I run a Sachs Paddle with LUK Dual Mass, done countless track days with no sign of giving up..
Once my dual mass gives up (I`m guessing it wont be long) I`ll be putting a SMF in
Hi, I'm new here and maybe not expert but reading all the thread I arrived to this. You got stage 2+ but you didn't say the exact torque value you have and basically the stage 2+ is on 370 lbft and this clutch kit is rated on 380-430 lbft so should hold it without any problem, from that we can arrive to tell that your clutch kit is faulty and if I was in you I'll claim it ASAP due to the guarantee that basis on mileage (I think 20000+ anyway).
http://www.darksidedevelopments.co....-disc-for-6-speed-02q-dual-mass-flywheel.html
Organic Clutch Disc (Sachs Flywheel) - 881864 999502 / 881864999502
- Rated by Sachs to 355Ft/Lbs+ for the Organic Disc
Matches the part number that i have in mine but I've never had mine on a dyno so can't say how much torque its putting out. But i know for a fact that if 355 ft.lbs is the clutches limit then APR stage 2+ will be very close to, if not more than that.
Where does it say it's rated from 380 to 430ft lbs?
The only figures I've ever seen from suppliers is the above numbers that I originally posted.
Any figures I've ever seen apart from the ones from dark side developments have always been made up estimates from forum members based on previous experiences and what their mate was running.
R Tech have come back to me with the following which seems fair enough:
"The upgrade clutch kits should take as a k04 can possibly give 380-430lbft with no issues if its started slipping now there it could be down to the clutch clamping pressure, we have never see a upgrade clutch exceed the clamping force from stage2+ tuning."
The options available to me are to either downgrade the map or start talking to the manufacturer. I'm not entirely clear on what clamping pressure is and how this would cause the issues I'm experiencing, can anyone help explain this please?
@Rick @ Unicorn Motor Dev. , have you ever heard of these types of problems with your customers or APR owners that have come to you?
What u going to do ???Looking at the Sachs site again, the clutch is rated to 550nm which is about 405 ft/lbs http://www.sachsperformance.com/Sachs-Performance-Kupplung-Sportkupplung/Audi/Audi-A3-8P1-05.03->/S3-quattro-188-kW-;-02/2007-:::2_3_820_844.html so no reason for it to have failed with what I'm running.
That's pants hopefully they have good customer support!Still waiting to hear back from Sachs, ultimately going to have to get it in the Garage and stripped down but want to know Sachs position before hand :-(
DMF is repalaced normally when stopping to do its function, but as you say your one got few (4k + if remember good) miles so is inneded, I replaced my at 160k miles (aswell clutch) cause wasn t sure of condition but is still fine... Just to say DMF function is to not transfer the vibrations caused by engine to gearbox.Hi Guys, just wanted to add a quick update on this. The clutch has been getting worse over the last few weeks and the biting point seems to have got higher as well, I've had to use the car and despite being a gentle as possible the occasional slip has been unavoidable particularly on the motorway.
However, Sachs have sold me a replacement at a discount which is being fitted on Wednesday and if the old clutch is found to be faulty (will need returning to them for testing), they have agreed to refund the full cost of the clutch and pay for the fitting so I'll update again on Wednesday when I know a bit more. I was surprised to see this thread http://www.audi-sport.net/xf/threads/uprated-clutch.248597/ though where it looks like more people are suffering with slip although no mentioned of mileage done since fitting on these.
Quick question, the DMF was replaced at the same time when I had the clutch fitted and a few people I've spoken to said that it should be fine to keep the existing one, what do people think?
That's some serious slippage on the flywheel. The clutch looks OK from the pictures but I guess Sach's examination will prove that.
Do you know if the flywheel when fitted was wiped down of any grease or oils before fitting?
Had my spec 3+ and smf installed on Thursday no problems so far but then it's massive overkill for my car in its current spec
The picture is a bit deceiving, its not the flywheel it's the inside of the clutch cover, it's just sitting on top of the flywheel in the picture. It's very dust but not badly marked from the slipping but also displayes the heat marks. The flywheel displayed similar 'leopard skin' heat marks but was not scored although this was replaced as well because of the heat cycling there was a risk of premature failure, this was pointed out to Sachs but they've not asked for the flywheel to be sent back. With regards to fitting, it will have been done correctly and bear in mind everything was fine for 8000 miles before the problems started.
