This set I converted for a member on this forum.
Both lamps split:
items removed and sent to local Body shop for paint:
light deflector removed, and the nub at the top needs to be shaved off:
Tool of choice is a Dremel for trimming:
After the trimming, done this as the projector bowl will NOT sit as it should:
Also trimmed the rear smooth, when using the Morimoto Mini H1 the Shaft is small that you screw to so you need as much space as you can back there:
Projector locked in tight and mounted:
Shrouds are the IRIS chrome:
As we are using a 2.5IN projector a centric ring is needed, I always glue it to the shroud then to the projector so I know its secure.
Painted parts back from the body shop, went with matte black:
And Complete:
