Esp fault with traction control light
Kirkcaldy Fife
while driving home tonight my esp light came on along with the traction control light and my car went into limp mode this has happened once before so i pulled over turned the car off then on and it reset. I have only had my S3 a few months any help would be great
Has anyone had anything similar happen or know of common problems with the esp system
thanks Mike
Mike, have you had a vcds scan done to see if any faults show up? What year is your car?
Not yet as it only happened about half an hour ago my friend has vcds so will get him to have a look over the weekend
Reactions: Sandra
Mine had the same fault, turned out be a rear wheel speed sensor.
Reactions: PORTER22
Yes, originally using a Snap On Ethos+ and then confirmed using VCDS.
Upon inspection it turned out that the sensor had actually snapped just behind the multiplug.
