Car is a 2007 2.0Tdi 170PD with 85k miles on the clock.
There is a really weird noise coming from the engine bay. I can clearly hear it inside the car on idle.
It is a hissing but metallic sound coming from the turbo side of the engine.
Noise isn't regular and doesn't change at increased rpm.
Have a look here: 10sec, 12sec and further.
I scanned the car today. Bear in mind that I had it only few days.
It came up with loads of engine errors. Cleared them and after running the engine for few minutes, it came wit no
errors at all. There are no lights on the dash. I can't drive it at the moment because it isn't taxed and doesn't have and mot.
These are the errors for engine, but after clearing them nothing comes back:
I really don't think this issue is related to DPF. Any ideas?
008194 - Particulate Trap Bank 1
P2002 - 006 - Efficiency Below Threshold - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 1
Fault Frequency: 17
Reset counter: 16
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2112 /min
Torque: 144.0 Nm
Speed: 50.0 km/h
Pressure: 0.0 mbar
Text: 0 mbar
Text: 312 C
Temperature: 22.5°C
001137 - Exhaust Pressure Sensor 1 (G450)
P0471 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 16
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 136.0 Nm
Speed: 5.0 km/h
Pressure: 0.0 mbar
Text: 21 mbar
Text: 272 C
Temperature: 16.5°C
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 136.0 Nm
Speed: 5.0 km/h
Pressure: 0.0 mbar
Text: 268 C
Temperature: 16.5°C
Text: 0 mbar
009299 - Diesel Particle Filter; Differential Pressure Sensor
P2453 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 136.0 Nm
Speed: 5.0 km/h
Pressure: 0.0 mbar
Text: 0 mbar
Text: 272 C
Temperature: 16.5°C
000665 - Boost Pressure Regulation
P0299 - 006 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2112 /min
Torque: 144.0 Nm
Speed: 30.0 km/h
72.93 %
Voltage: 13.56 V
Pressure: 1831.8 mbar
Pressure: 937.2 mbar
001026 - EGR System
P0402 - 006 - Excessive Flow - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 37
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2048 /min
Torque: 144.0 Nm
Speed: 30.0 km/h
0.00 %
4.68 %
Mass Air / Rev.: 550.5 mg/str
Mass Air / Rev.: 397.9 mg/str
000258 - Mass Air Flow Sensor (G70)
P0102 - 007 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 5
Fault Frequency: 9
Reset counter: 39
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
99.45 %
Voltage: 11.75 V
Mass Air / Rev.: 850.2 mg/str
Mass Air / Rev.: 0.0 mg/str
000801 - Engine Speed Sensor (G28)
P0321 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 160 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Time: 0.02 s
Angle: 0.0 °
Bin. Bits: 00000000
Bin. Bits: 00000001
Freeze Frame:
Fault Priority: 1
Fault Frequency: 17
Reset counter: 16
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2112 /min
Torque: 144.0 Nm
Speed: 50.0 km/h
Pressure: 0.0 mbar
Text: 0 mbar
Text: 312 C
Temperature: 22.5°C
Freeze Frame:
Fault Priority: 1
Fault Frequency: 16
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 136.0 Nm
Speed: 5.0 km/h
Pressure: 0.0 mbar
Text: 21 mbar
Text: 272 C
Temperature: 16.5°C
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 136.0 Nm
Speed: 5.0 km/h
Pressure: 0.0 mbar
Text: 268 C
Temperature: 16.5°C
Text: 0 mbar
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 136.0 Nm
Speed: 5.0 km/h
Pressure: 0.0 mbar
Text: 0 mbar
Text: 272 C
Temperature: 16.5°C
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2112 /min
Torque: 144.0 Nm
Speed: 30.0 km/h
72.93 %
Voltage: 13.56 V
001026 - EGR System
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 37
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2048 /min
Torque: 144.0 Nm
Speed: 30.0 km/h
0.00 %
4.68 %
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 39
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
99.45 %
Voltage: 11.75 V
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 160 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Time: 0.02 s
Angle: 0.0 °
Bin. Bits: 00000000
Bin. Bits: 00000001
