Window trim
AndyW!
Scarborough
Hi All,
Can anyone recommend what i can do to sort this bit of window trim out?
As you can see the trim appears to be bent on both ends.
Unsure on how or if i can remove this trim to repair or replace.
Pics below.
20150811 183104 resized
20150811 183115 resized
20150811 183052 resized
It looks like it's been repaired as the red looks slightly different. Might have been refitted incorrectly.
Door card off i believe to access that trim.
They're riveted on, strip the door down alittle and you will be able to get at the rivets, drill the old ones out if needed and replace - just have a spare trim on standby as i'm guessing that some one has tried to remove it but pulling it upward, braking the rivet holes.
