Will these wheels fit?
PORTER22 A5 Joined Jul 5, 2015 Messages 62 Reaction score 9 Points 8 Location Kirkcaldy Fife Jul 27, 2015 #1 Attachments Screenshot_2015-07-27-00-03-23.png 919.2 KB · Views: 212
Sayam Well-Known Member VCDS Map User Joined Feb 18, 2012 Messages 2,801 Reaction score 664 Points 113 Location West Yorkshire Jul 27, 2015 #2 ET40 may be too low if you want to use 225/40/18 tyres. Can you get them in ET45 which would be perfect?
Sayam Well-Known Member VCDS Map User Joined Feb 18, 2012 Messages 2,801 Reaction score 664 Points 113 Location West Yorkshire Jul 27, 2015 #3 ET40 may be too low if you want to use 225/40/18 tyres. Can you get them in ET45 which would be perfect? Reactions: PORTER22
PORTER22 A5 Joined Jul 5, 2015 Messages 62 Reaction score 9 Points 8 Location Kirkcaldy Fife Jul 27, 2015 #4 Thanks for the reply nope only Et 40 I emailed them this moring and they said the will fit ok what tyres do you recommend tho
Sayam Well-Known Member VCDS Map User Joined Feb 18, 2012 Messages 2,801 Reaction score 664 Points 113 Location West Yorkshire Jul 27, 2015 #5 225/40/18 will definitely rub on the rear... Try a 215 tyre with the appropriate cross section to maintain the same circumference You may want to try 225 tyres with arch screw removed, it may just clear? Reactions: PORTER22
PORTER22 A5 Joined Jul 5, 2015 Messages 62 Reaction score 9 Points 8 Location Kirkcaldy Fife Jul 27, 2015 #6 Yeah think I may remove the screw will 225 40 be ok on the front I take it
PORTER22 A5 Joined Jul 5, 2015 Messages 62 Reaction score 9 Points 8 Location Kirkcaldy Fife Jul 27, 2015 #7 Sayam said: 225/40/18 will definitely rub on the rear... Try a 215 tyre with the appropriate cross section to maintain the same circumference You may want to try 225 tyres with arch screw removed, it may just clear? Click to expand... Check this out i think they will be ok my s3 is on standard suspension what do you think
