fitting 19s on avant
I'm lowered and run 19×9 all round with the fronts spaced to ET42 which gives a few mm between the wheel/arch wheel/strut, and the rears are spaced to ET40 with 235/35/19 rubber with no rubbing, or catching, but I think you would struggle with 9.5" on the front.
Don't forget the B5 RS4 has wider arches than a standard car.
Yea I did forget that the rs4 has the wider arch thanks
Also my avants low at the back on standard sings nothing broken just sits low as this seems to be the norm
There is loads of room in the rear arches mate, I managed to run the 255/40/19 tyres that came on the alloys with a 5mm spacer for 5 days while I waited for my rear tyres to turn up.
I've also ran 18×9 with 235/40/18 tyres with ET35 on the rear with no rubbing.
I've run 235/35/19's on a 9.5 et 45 on the front and rear and it was OK.
I'm on air though - how lowered are you?
15
19
N8
662
