Q7 Audi Q7 2007 Starting cold issues white smoke long crank
k99shm
hi all
I am new to the forum
I was wondering if anyone would be able to help.
Recently in the mornings I seem to be having trouble starting my car.
it will crank for about 8-10 secs and then blow some white smoke from exhaust. An error message "EPS/ABS fault See owners manual" appears briefly before disappearing. There are no warning signs on car after it starts.
for the rest of the day it will fire up first time. I have done a VCDS scan as below:
Thursday,25,June,2015,18:18:08:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20140905
VIN: WAUZZZ4L68D002763 License Plate:
Mileage: 51247mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
55 56 61 62 67 6D 6F 72 76 77
VIN: WAUZZZ4L68D002763 Mileage: 82450km/51232miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4L0 910 401 T HW: 4L0 907 401
Component: 3.0L V6TDI G000AG 0010
Revision: --H04--- Serial number:
Coding: 0011775
Shop #: WSC 31414 790 00001
VCID: 3363699752B7BA8656F-8066
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
Component: AL 750 6A 1000
Revision: 00H64000 Serial number:
Coding: 0000504
VCID: 84017A4BC7994D3E3F5-80D1
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0103569
VCID: 295F8BFF807BF056EC3-807C
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 82419 km
Time Indication: 0
Date: 2015.06.25
Time: 07:57:53
Freeze Frame:
Count: 0
Count: 2113
Count: 128
Count: 35072
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100780879
Coding: 0000147
Shop #: WSC 00019 210 90927
VCID: E3C359D722D7EA0666F-80B6
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0053
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L1 910 732 G HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 386EU077544405
Coding: 0002002
VCID: 2E5578E3B995976E391-807B
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000000753074
Subsystem 3 - Serial number: 0107.05.070000000100011055ˇ
Subsystem 4 - Serial number: 011055ˇ
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000030045812
Coding: 0001046
VCID: E1CF53DF38CBF816743-80B4
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 82419 km
Time Indication: 0
Date: 2015.06.25
Time: 07:57:57
Freeze Frame:
Voltage: 9.70 V
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0012121
VCID: 316F639FA8AB8896243-8064
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H09 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 B HW: 4L0 035 110
Component: MP3-Changer H43 0390
Revision: 00043000 Serial number: AUZ5ZBG1063580
Shop #: WSC 00000 000 00000
VCID: 1E35A823C93507EE891-804B
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH42 0230
Revision: 03H42000 Serial number: 00399D031LY7
Coding: 0014129
Subsystem 1 - Serial number: 6332QSME312639717
Subsystem 2 - Serial number: 6342QSME312629256
Subsystem 3 - Serial number: 6352QSME312F773FU
Subsystem 4 - Serial number: 6362QSME2F7C095B$
Subsystem 5 - Serial number: 63734SME0D0654590
Subsystem 6 - Serial number: 63834SME0D06517D4
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks‰ulenmodul H08 0230
Revision: 00H08000 Serial number: 90025071220637
Coding: 0102142
VCID: E6C540C3D1E59F2E811-80B3
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H02 0030
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 981 B
Component: KOMBIINSTR. M73 H21 0220
Revision: 00600000 Serial number: 6EL530W57
Coding: 3617458
Shop #: WSC 44253 001 1048576
VCID: 234399D7E2572A06A6F-8076
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 D
Component: Heizgeraet H08 0080
Revision: 0000000C Serial number: 00000009014264
Coding: 0000001
VCID: E0C956DB33C1F11E7BD-80B5
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0751280E1
Coding: F55BBE7F30720200
Shop #: WSC 00551 210 91539
VCID: 2D577FEFB493EC7600B-8078
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
Shop #: WSC 00551 210 91512
VCID: 2A5D74F3857DFB4EE59-807F
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 399A1087598193
Shop #: WSC 00508 210 59464
VCID: 3B7341B77AE772C68EF-806E
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00000000 Serial number: Åsv
Coding: 0002651
VCID: 2F6B65E7BE9F9E66327-807A
Address 46: Central Conv. Labels: None
Part No SW: 4L5 910 289 C HW: 4I0 907 28< C
Component: Komfjrtgera`t H02 0040
Revision: 0040 -(- Serial number: 04043501720000
Coding: 7610619
Shop #: WSC 96950 788 00001
VCID: 3567578F5CC3A4B678B-8060
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000029069
Coding: 0000023
VCID: 28598EFB9B71C95EF3D-807D
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000046551
Coding: 0011101
VCID: DEB5682309B5C7EE491-808B
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00000000 Serial number: gu
Coding: 0002651
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000008
VCID: 3D774FAF64F37CF6B0B-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388E$077625709
Coding: 0000001
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0002058
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000704300314
Shop #: WSC 12336 024 394758
VCID: 3665508341C5AFAE711-8063
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: ECD132EBCF09A57ED75-80B9
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD25.05.07--H21001001B0076ˇ
Subsystem 4 - Serial number: 1B0076ˇ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002776535-----
Coding: 0003587
VCID: 264580C39165DF2EC11-8073
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0002058
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06330712905191
Coding: 0201146
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007669035
Coding: 0010900
VCID: 2C5172EB8F89E57E175-8079
End ---------------------------------------------------------------------
