- Joined
- Apr 28, 2015
- Messages
- 130
- Reaction score
- 63
- Points
- 28
Writeup for retrofitting auto-dimming rear view mirror and coming home/leaving home function to any A4 B6 with highline equipment.
This retrofit requires some knowledge of car electrics, and a registered version of VCDS lite.
How do I know if my car is highline?
If you have bulb out warning - you have highline
If your CECM part# is 8E0 907 279 E or F - you have highline
NB! You need CECM 8E0 907 279 F, which is the only CECM supporting AUTO lights and CH/LH function.
I did not do the auto dimming wing mirrors, hence it's not a part of this DIY.
Disclaimer: I am not a mechanic, and will not take responsibility for anything that may be damaged or broken while using this DIY on your own vehicle. This DIY is intended as a guide only.
Prerequisites
Parts
Wiring
Let's get started
DISCONNECT YOUR NEGATIVE BATTERY TERMINAL.
Remove interior dome light cover (just pulls out)
The second plastic cover also just pulls out (has 4 plastic clips on it)
Remove two philips screws to remove the base of the panel
Then you can pull the base downwards to remove it
Locate this plug, and remove it (two wires to be inserted here later)
Remove the sun blind on the drivers side, by pulling out this cover and unscrew the T25 bolt behind it
You also need to remove this handle to loosen the A-pillar trim (Torx 25)
Loosen the A-pillar trim by unclipping the 3 clips along the A-pillar (note: my new wiring is shown here, not yet zip tied)
Pull out your old headlight switch by pushing, turning clockwise and then pulling outwards.
Remove the plug. Note: this is also a way to check if your car is highline - high gauge wires indicating highline, low gauge (thick wires) indicating lowline (lights are then operated by switch, not CECM).
This cover pulls straight out
Remove drivers kick panel - 3x 8mm hex bolts, first one located as shown on picture, last 2 located above the pedals (one on each side)
Unscrew and unclip the fuse panel and pull it downwards to expose the CECM.
Unclip all 3 plugs on the CECM and locate the 32-pin grey connector - it should look like this
Remove the purple lock, and pull out the white center frame
Prerequisites
Parts
- CECM (Central electrics control module) - paid $37
8E0 907 279 F (always installed in S4) - Auto-dimming rear view mirror w/ light sensor - paid $50
8E0 857 511 (Gentex 015621) - Headlight switch w/ AUTO position - paid $16
8E0 941 531 B - CH/LH switch - paid $25
8E1 919 094 B (LHD, for cars with xenon)
Wiring
- Plug for CH/LH switch (8 pin) - paid $10
8Z0 972 883 - Plug for auto-dimming mirror (6 pin) - paid $10
4B0 971 833 - Wires 20-22 AWG, 3 metres - paid $15
White, black, grey, green - Cloth tape for OEM appearance - paid $3
For OEM appearance of harness - Audi repair pins - paid $10 for 10 pcs
000 979 018 E
Let's get started
