- Joined
- Jan 31, 2003
- Messages
- 78
- Reaction score
- 0
- Points
- 6
- Location
- Glasgow, Scotland
- Website
- www.djmotorsport.com
The Formula Palmer Audi Car.
Originally designed and manufactured by Van Diemen International.
Chassis
Advanced full aluminium honeycomb monocoque, the basic structure of which complies with the current FIA F3 safety regulations in respect of lateral intrusion, frontal impact and driver protection.
Engine
Manufacturer Audi
Capacity 1.8 litres
Cylinders 4
Valve Gear Twin overhead camshaft, 20-valve head
Fuel System Pectel Electronic fuel injection
Aspiration Water cooled Garrett T3 turbo, intercooled with closed loop boost control
Maximum power 275 bhp with 325 bhp available on driver activated over-boost
Cooling
High efficiency aluminium radiator with low drag coefficients housed in side pods. High efficiency oil/ water heat exchanger. Air/air intercooler for inlet-charge cooling.
Gearbox
5 Speed Hewland FGC transaxle with magnesium casing and limited slip differential.
Suspension
Advanced push-rod activated systems all round incorporating anti-squat and anti-dive operates on wide based aerofoil section wishbones mounted in double shear, which include the latest anti-intrusion bar requirements. Uprights are cast in heat-treated aluminium and incorporate large diameter angular contact bearings. Ohlins dampers adjustable in bump and rebound. Fully adjustable front and rear anti roll bars.
Brakes
Lightweight double acting 4 pot callipers and ventilated floating discs all round. Fully aero quipped with cockpit adjustable front-to-rear bias.
Aerodynamics
Front wing Full width one piece carbon composite - adjustable main plane and flaps
Rear wing Three upper elements profiled similarly to current FIA F3000 specification and incorporating a lower carbon composite element mounted on the gearbox.
Composite end plates.
Floor 50 mm stepped floor.
Tyres
Specifically designed and supplied by Avon to suit requirements of Formula Palmer Audi. Both front and rear are new, specially made for the car, and between F3 and F3000 in size. Construction and compound developed to provide a tyre with consistent grip and good durability.
Front Slick and wet Size 250/ 570 R13
Rear Slick and wet Size 300/ 600 R13
Fuel System
A 42 litre minimum usable capacity foam filled cell to FIA/ Spec/ F3 specification located behind the driver's seat bulkhead and in front of the rear monocoque bulkhead.
Cockpit
Detachable 10 Momo steering wheel acting on specialist Van Diemen rack and pinion unit.
Stack system electronic instrumentation and data acquisition, monitoring driver inputs (steering and throttle position) plus essential engine data.
Dimensions
Wheelbase 2667 cm
Front Track 1473 cm
Rear Track 1447 cm
Dry Weight 530 kg
Performance
Top speed 270 kph or 168 mph.
0-100 kph 2.8 seconds
0-160 kph 6.2 seconds
DJ
Chassis
Engine
Manufacturer Audi
Capacity 1.8 litres
Cylinders 4
Cooling
Gearbox
Suspension
Brakes
Aerodynamics
Tyres
Fuel System
Cockpit
Dimensions
Wheelbase 2667 cm
Front Track 1473 cm
Rear Track 1447 cm
Dry Weight 530 kg
Performance
DJ
