Although this issue is dealt with on several threads I had to pull knowledge across many to finally fix my problems so this is hopefully a definitive bring everything together guide on overcoming a 2100 manifold flap error on my 2.0tdi. This part failure causes the EML to come on at minimum and stops the car from operating at worse.
Firstly remove the engine cover. The manifold flap is located at the front of the BKD engine smack bang in the middle, to the right of the alternator. It has a large ducting air hose feeding to the base, The motor that operates the flap usually fails due to teeth being ground off on the winding mechanism within the motor. With my car there was about a weeks notice things weren't going well with grinding noises coming from what I thought at the time was one of the fans.
When the flap fails it can fail in three positions, closed which is the engine shut down position, open which is the engine running position or partially open which is neither here or there. The symptoms vary as does the secondary error code to the main 2100 manifold failure. You'll usuall get a second 2101 or 2102 code which registers the position of the flap as closed or open. If its failed in the closed position the engine can't breath so it wont start. If its failed in the open position then the car will run fine but have a constant EML warning on the dash. If its failed in a partially open position then the car will probably run rough and lack power due to the restricted air supply. As an interim fix, to get the car running from a flap closed position the air hose can be withdrawn and fingers inserted to the base of the flap control to manually force the flap open.
When you get a replacement part and I got mine from a German reseller on eBay for £92 delivered (£240 from Audi UK) for a claimed OE part. To remove the broken manifold flap there are three bolts (allen key head), the cable clip and the air hose that need to be negotiated. The wire clip needs to be removed with a flat head screwdriver into the notch on the side (which isn't visible becuase of the angle). If you are unfamiliar with removing this type of clip then I'd recommend practicing on the alternator clip first as that is adjacent with good access.
To seperate the air hose there are two approaches. Try to move the clip around the body by arounf 20 degrees and this will free the hose clamping. You can see how the clip functions from the new unit being fitted. If the clip doesn't rotate easily then just remove it completely by inserting a screwdriver into the raised notch on the clip and prising off.
The three bolts are all a little fidly due to the cramped space between the radiator and the manifold. Two are the same size and the third longer so remember which position the longest bolt was removed from and obviously fit the replacement unit with the bolts in the same locations.
Fitting the new unit is just the reverse of the removal process. The bolts are just nip tight, I remember reading somewhere they are supposed to be 10lbft of torque though you'll never fit a torque wrench in the space available.
With the flap replaced you now need to check the fuse number 24 (10A) in the fuse box by the battery unit in the engine bay. That had blown on my car. The fuse is apparently located alongside the 458 relay on earlier models.
Codes cleared and restrated all fine. EML remained off on a restart. However error codes returned on the second start up. Cleared codes and the same happened again, and again and again. The flap could be heard operating, it audibly opens on ignition on and audibly closes on ignition off. Seeing clearing codes wasn't keeping them cleared I performed an ECU reset:
ECU reset:
20 minutes battery disconnected
5 minutes ignition on (not started)
Started - 5 minutes left idling
Drive - all lights extinguish
Result - no EML light returning. Sorted.
ECU reset:
