If you push down the LHS scroll button on the steering wheel it'll fast forward the current playing cd track.
There are some features fitted across the whole VAG range of motors that some people will miss. Here's a couple to start you off-----------
1. Centre sun visor above the rear view mirror. It's just a small plastic pull down flap on the front edge of the headlining.
2. Parking place for fuel filler cap. The cap has 4 notches around the edge, use any 2 of these to hook it on to the top edge of the filler flap to stop scratches when it dangles on the rear wing.
Add some more if you can.
If you have dual zone aircon, you can sync the temp control for both sides by pressing down the driver side air con temp knob for a few seconds. Try it!
here's one i found after a year of ownership lol, if i hold down the unlock button on my fob all the windows lower.![]()
yep, the B7's are full of little tricks and surprises....some better than other though..lolHaving had various cars with dual climate control, I found not having a sync function annoying. So finding that it is available in my A4 is great!!
Yeah...found out mine has the sunroof and windows lock with holding the lock button...my girls thought it was magic! Didn't dare trying the unlock button feature as well all in the same day in case I passed out with the excitement!!![]()
I have had my Audi for 6 months and only just found out that it has factory fitted Bluetooth phone kit.
After reading through this thread i went out to check mine, i didn't think the concert 2 would have it, not even mentioned in the book that i could see, but a quick google revealed how to pair up, i was like a kid at xmas, shame it doesn't look like i can stream music with it, but still happy with the handsfreeI've just found out i have bluetooth handsfree after 2 years of ownership... Doh! Haha didnt even think to see if i had it!
I quickly disabled that function after coming home one night when it was snowing to find ALL windows in the car wide open!! Luckily it had only started snowing not long before, but could have been bad if left all night. It had happened a few times prior to that also, but all on dry days, so didn't bother about it. After that snow incident it was a case of never risking it again.
Now our keys will close the window with the fob, but will not open them.
Gonna look under my seats tomorrowFound I had the under seat storage after reading another thread on here, not sure how useful it is as its a pretty small space, better than nothing I suppose!
Thanks for the info,works a treat.Throttle alignment.....
1.Insert key and turn to the ignition light on position
2.depress the throttle for a frew seconds, turn the key back as if to remove it but do not remove key. Take foot off throttle.
3. Wait 2 mins
4. Remove key, reinsert key, start engine, should notice more even throttle and smoother do this every few weeks
Sent from my G8141 using Tapatalk
I only found the sun visor ver the rear view mirror the other day, mind = blown
My 07 B7 convertible, wifes mk1 TT and a mates old 02(?) RS6 had it so I suspect so. It's just a little plastic flap above the rear view mirror. Such a simple thing but you'll wonder why all cars don't have it.I can't find this anywhere. Do all audis have it?
Found out after getting ****** wet through shouting and swearing whilst changing a flat on 2008 a4 sline cab.....
The boot carpet handle turns 45 odegrees to hold up on the rear lip of boot.... Only found this out after my attempts at holding it up by putting tool box under it etc.... Bloke at tyre fitters did it... Wish I knew an hour and half ago!!!!!
