fault code n373
thedebo
hi guys anyone had this esp fault code it also said Valve for Controlling Clutch Operating Angle any help appreciated ?
02248 - Valve for Controlling Clutch Operating Angle (N373)
02248 - Valve for Controlling Clutch Operating Angle (N373): Mechanical Faulty
02248 - Valve for Controlling Clutch Operating Angle (N373): Mechanical Failure
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • Fuse(s) faulty
  • Valve for Controlling Clutch Operating Angle (N373) faulty
Possible Solutions
  • Check Fuse(s)
  • Check/Replace Valve for Controlling Clutch Operating Angle (N373)
    • Check Measuring Value Blocks (MVB) for proper Supply Voltage
Special Notes
  • Valve for Controlling Clutch Operating Angle (N373) may be part of the All-Wheel-Drive/Haldex Control Module (J492) and cannot be replaced separately, a Repair Kit including an optimized Control Module may be available though.
cheers myke its going in to garage on Monday I will work threw the list see where I am at, ill do haldex service as well hopefully doesn't need a new controller, I found a place on the internet autofaultfinder who sorts controllers if it cant be done in garage ill send it of to them next bet after that second hand controller so hopefully gets done within next week or two , have to admit I am enjoying it in front wheel drive mode at the minute
