- Joined
- Sep 12, 2010
- Messages
- 35,065
- Reaction score
- 15,938
- Points
- 113
ALL NEW UK SPECIFICATION AUDI RS 3 SPORTBACK IS RARING TO GO
Price and specification now fixed for UK versions of 367PS Audi RS 3 Sportback ahead of March on-sale date
All new second generation RS 3 Sportback available to order in the UK from March 2015 priced at £39,950 OTR - first customer deliveries in summer
Most powerful production five-cylinder engine in Audi RS history with 367PS and 465Nm from 1,625rpm to 5,550rpm
0 – 62mph in 4.3 seconds – 0.3 seconds faster than the previous model – 155mph governed top speed can be raised to 174mph on request
Lower weight, faster-shifting S tronic twin-clutch gearbox, faster-reacting quattro drive
The all new 367PS Audi RS 3 Sportback is now en route to the UK, and as the most powerful compact hatchback currently in series production will be even more adept at catering for sports car devotees who also need to take care of everyday necessities like the school run and the supermarket sweep. Capable of snapping at the heels of exotica with its 4.3-second 0-62mph sprint time and potential top speed of up to 174mph, the new five-door, five-seat Sportback will weigh in at £39,950 OTR. It will become available to order in March and reach its first UK customers in the summer.
The new entry point to the formidable Audi RS range is born of impeccable breeding – it is based on the current World Car of the Year and features the latest evolution of the evocative 2.5-litre five-cylinder TFSI – winner of the International Engine of the Year Award in the 2.0 to 2.5-litre category on no less than five consecutive occasions since 2010. Equally reassuringly, it shores up the extraordinary performance and handling produced by bringing these two elements together with the latest generation of quattro all-wheel-drive.
The 367PS output from the aurally characterful 2.5-litre TFSI is complemented by peak torque of 465 Nm (343.0 lb-ft), which is available right from 1,625rpm through to 5,550rpm, ensuring that huge reserves of performance are always at the driver’s disposal.
With a power-to-weight ratio of 241PS per ton achieved by trimming an additional 55kg compared with the previous RS 3 Sportback, the latest car needs just 4.3 seconds to hit 62mph from rest, and with a suitable stretch of Autobahn to hand could continue to an electronically governed 155mph top speed. Drivers looking for optimal performance can also specify an optional increase to 174mph.
EU6-compliant
Compliance with stringent EU6 emissions legislation confirms that the latest edition of the classic five-cylinder unit is as frugal as it is feisty. With the help of a recuperation system, a demand-controlled oil pump and a new generation start-stop facility which increases the duration of engine ‘downtime’ at each stop, the latest RS model is capable of returning up to 34.8mpg, corresponding to CO2 emissions of 189g/km.
Butterfly valves in the exhaust system control the exhaust flow and deliver a suitably full-bodied and characterful note that varies with engine load and speed. For the first time in an Audi model at this level, a sports exhaust upgrade which deepens the tone even further is also available as an option. The driver can control the volume and depth of the output in both set-ups via the standard Audi drive select adaptive dynamics system.
A seven-speed S tronic twin-clutch transmission reworked to offer even faster shifts directs the power to the quattro permanent all-wheel drive system with its redesigned and lightened multi-plate clutch and torque vectoring capability. The clutch is mounted on the rear axle in the interest of balanced load distribution, and the parameters its bespoke RS 3 software works to can be controlled via the Audi drive select system.
Depending on the situation, it can send between 50 and 100 percent of the available torque to the rear axle, and when Audi drive select is in dynamic mode and the ESC Electronic Stabilisation Control system is in its sport setting, power is transferred to the rear sooner and in greater amounts for even greater agility and more direct turn-in.
The state-of-the-art all-wheel-drive system adds a further measure of control and composure to the inherently agile RS-specific chassis with its wider track front and rear, uprated MacPherson strut front suspension with purpose-built lightweight aluminium pivot bearings and four-link rear set-up. The new electromechanical progressive steering system which is capable of varying its ratio as a function of steering input also helps to emphasise the quick-witted feel.
From the driver-focused section of the options list the Audi magnetic ride adaptive damper system can be added to level out ride and handling to an even greater degree, and the steadfast RS-specific disc brakes with their efficiency-boosting wave contour discs, eight-piston calipers and bespoke lightweight friction rings upfront can be further upgraded with carbon fibre-ceramic front brake discs – a first for a car at this level.
Standard LED headlamps for UK versions
Classic RS visual references signal the special qualities that all these features confer to the outside world. In UK specification versions the nose with its high-gloss black, honeycomb-look singleframe grille and pronounced air intakes is set off by standard LED headlamps and daytime running lights. In profile the standard 19-inch alloy wheels snugly filling their arches, flared front wings, chiselled sills, matt aluminium-look mirror housings and large roof spoiler also catch the eye, and the rear with its remodelled bumper and high-gloss black diffuser insert is dominated in each corner by a large, oval RS tailpipe.
Customers can choose from a palette of eight paint finishes to either accentuate or subtly play down the purposeful look – it includes the two new shades Nardo grey and Catalunya red, metallic, the latter available exclusively for the RS 3 Sportback.
In the equally focused interior the standard sports seats are upholstered in Fine Nappa leather with contrasting stitching in rock grey, and the driver’s is perfectly positioned in relation to the flat-bottomed RS multifunction sports steering wheel with its leather and Alcantara trim. Stainless steel pedals, Alcantara door inserts and inlays in either 3D design black or optional Aluminium Race or Carbon also signal intent. High-quality applications in gloss anthracite black frame the instruments, which include black-faced dials with red needles and white scales, plus a driver‘s information system enhanced by a boost pressure indicator, an oil temperature gauge and a lap timer.
In addition to LED headlights, standard equipment highlights for UK RS 3 Sportback models include the acclaimed MMI radio with its electrically folding colour screen, navigation preparation, Audi Music Interface iPod connection, Bluetooth mobile phone connectivity, front seat heating and the parking system plus with acoustic and visual guidance.
Choice options include newly developed RS bucket seats bringing a 7kg weight saving over the standard sports seat, an RS 3 interior design package with red accents on the seats, knee pads, air vents, floor mats and seat belts and MMI navigation plus with MMI touch, which through its Audi connect function beams internet-based services to the car.
EU6-compliant
