Its a terrible beep I turned it off after a day . . .I can't get beep when alarm is enabled to work. It just keeps saying trouble connecting. Other stuff does.
If I activate Audi Drive will I lose this when I press the car button?
Does Carista give you a Launch Control count?? Is that free or do you need to subscribe for it?? @Tashfeen ?? Guessing you’ll know this one.
Which menu is it under? I haven't seen it, but can't remember whether I have paid version or not, I thought I didYes, it does have launch counter. I am not too sure if the unpaid version does as I have the paid one which does
Sent from my ONEPLUS A3003 using Tapatalk
The Mrs took my car to work, otherwise I would have checked mineI believe it is under 'Service'. A colleague at work has borrowed mine otherwise I would've checked and let you know exactly where to look.
Just bought Carista,
Would anyone know if I can use OBD Eleven app on Android with the Carista adapater? I want to enable VIM and it seems its not possible with Carista...
What's VIM ?Just bought Carista,
Ive had this app for a while its handy as hell,inabled loads of stuff and cleared codes,ive tried it on fords and vauxhall and it doesnt work on them tho
I did all those on mine but found the mirror dip in reverse was awfulJust done these changes using the Carista app on our new to us used A4 Avant
1. Beep when alarm is armed
2. Unlock doors via remote - All doors on 1st press
3. Instrument cluster region - Was set to Germany, oddly. Altered to Great Britain
4. Gauge needle sweep at startup
5. Lap timer & oil temperature in dashboard
6. Flash hazard lights in emergency stopping
7. Require seat belt when releasing parking brake - No
8. Lower passenger-side mirror when in reverse gear
9. Remember position when lowering passenger-side mirror in reverse gear
10. Hidden green menu
11. & 12. ADS (Both of 2 steps done)
13. Show engine option in ADS menu
14. Show steering option in ADS menu
Remembered not to add 'Show suspension option in ADS menu'
I could never get the beep when alarm is armed to work.
What is the problem?
I found the mirror wouldn't return to the same spot and over a couple of reverses you would need to re-align the mirror! Sometimes in reverse I wouldn't want it to drop either so now-a-days I have it off by default by having the switch in another position. I'll use it if only needing to reverse park close to a kerb on the passenger side.
Same here, it doesn’t really locate to exactly the same position. Just move the switch to passenger side as and when I need it. It is handy for curbs on that side though. Especially with freshly colour changed wheels!!!
What can been done in hidden green menu?
Was,hoping to get visual parking aid is this still possible as I only have the beep
Did you ever get an answer to this bud?
Can you not close all windows on locking the car?? This doesn’t seem to work with a long press on the remote?
