I found out earlier today the same thing that i need the green menu, i also found a post on this forum explaining what to do. Thanks for replying though.Yes mate pretty sure i had to add mine via the green screen for it to show in the mmi. I've just come out to the car and had a look for you and you do need to do it on the green screen. If you have WhatsApp i just made a quick video for you showing you how to do it I'll happily send it to you.
Got the Carista OBD today, managed to get the needle sweep and acoustic alarm beeps, I can’t see anywhere on the available customisation menu about the visual parking display.
2014 A3 8v, it has rear acoustic parking sensors but wanted the display. Any ideas?
It’s there somewhere as I’ve only got rear sensors and managed to enable the visual display on the MMI. Keep searching and you’ll find it, mines a 10 plate A4
Switch buzzer and control unit bought used via ebay.
Mines like that too, don't bother with the dipped mirror anymore (used it all the time on my BMW as it just worked as intended)Just got the Carista obd from amazon. Connected first time
Enabled
Needle sweep
RIP cd
Passenger mirror dip in reverse
Hidden green menus
Beep on lock.
Oil temp/lap timer
Need to disable seatbelt chime
Enable vim
Mirror dip don’t go far and if I adjust it to where I want it the mirror only goes back a little on reset so I have to adjust again. Anyone else had this ?
Think I used OBDEleven for thatCan you enable vim without vag ?
You need to change it from the lower button on right hand indicator stalk. It should appear on the instrument cluster. Unless off course you didn't Save the changes in Carista in which case it won't appear.
I believe that the oil has to come up to operating temp before it will register on the display.
. Battery display should be in MMI. I don't think it is displayed anywhere on the cluster. Yeah sorted thanks just press reset button under stork got battery and interior light option also which was not saved great appYou need to change it from the lower button on right hand indicator stalk. It should appear on the instrument cluster. Unless off course you didn't Save the changes in Carista in which case it won't appear.
How do you activate hidden green menu ?Just got the Carista obd from amazon. Connected first time
Enabled
Needle sweep
RIP cd
Hidden green menus
Beep on lock.
Oil temp/lap timer
Enable vim
Word of caution here: you shouldn't change anything in hidden menu unless you know what you are doing - it is very easy to screw things up.
