My a3 2.0 tdi sport back :)
Conza
South East
canterbury, Kent
Hello this is my 1st audi :)
It's a little worse for ware now but will soon make her nice and straight again
It's 2007 Audi A3 2.0 tdi sportback 140 with the bkd engine
Sorry I'm Connor and I'm 21 and live in the South East
Reactions: Omy193
right 1st thing was to work out what i needed lol
sorry about quality
so i started ordering new bits
theres new rad,intercooler and condensor in the boxes
Reactions: Omy193
well heres my 1st car :) bit of a change going from that to this
right bumper off
so started repairing the bumper
right back to the car
i got a replacement bumper bar from the local vw audi breakers vag spares
only thing else that was realy broke was the airbox that ive plastic welded back together for the moment till i find a replace
trial fitted bumper after repair to check it was still ok round the lights etc
and then fitted all new genuine service bits including cambelt but used a cicolli water pump from euros with a metal impeller as dont like plastic ones
ordered some more plastic from tps
so moved it back to work and gave it to the painter to paint
regassed my aircon its great being a mechanic just get to do **** like this for free :)
bumper rubbed down
all painted
should be putting them on tomorrow then all done :)
not bad for won on a friday collected on the monday then all back together by saturday all painted and serviced
Proper "build" thread :applaus:
i do like to try :)
it has a knock when u start it to, all when u start and it feels like its under your bum
i looked at the exhaust and its miles away from everywhere, and can see any play in the dog bone mount
Good work so far
will be following progress :)
should have done a facelift/sline conversion since the front end was damaged, was the perfect excuse :p
Reactions: Ash187
Good work mate least you'll appreciate it after the hard work you've done! Lol
That's some great progress it will look mint once your finished :)
Right it's all together now and on the road I'll post pics later
Aswell as my esp/abs my dual mass is rattling about a bit :(
Few questions about the stereo
I have the factory fit symphony stereo that I want to keep
Will it loss it's code if I un plug it as want to remove the rest of Sony hand free kit which I need to remove the solidered wires
And what can I do with as want to keep like iPod etc
Many thanks connor
so my mother borrows my car to go shopping in as her fabia vrs isnt good enought and she informs me that a light has come on
so i plugged the vcds in at work and
so cleaned the air flow meter with brake cleaner to see if it comes back on as its running fine and set about changing the glow plugs
what a annoying place to put them nut managed the change the whole 4 in about 45 mins
Ive been hearing what sounded like a boost leak so on the ramp at lunch today and found this
the clip was bent etc so order new clips and new seals which turned up within half hour of ordering from tps :)
new vs old
also been having a bit of wheel wobble and what sounds like a wheel bearing from the back so spun the wheel and couldn't hear anything but noticed that the rear tyres are made by bct (cheap Chinese crap) so balanced all 4 and put them on the front to see if i loose my noise as had problems with them before at work and there brand new so don't see the point in replacing them yet.
think the person who balanced them was blind lol,
ordered the ashtray blank today which will be here tomorrow so ill get some pics up of that and have another go at brake light switch
Reactions: Ash187
i like this thread... a good old fashion build thread! although i also think you should have facelifted it... could of bought cheap damaged bumper and other bits.
Good build thread, interested to see what else you do to it!
got my ash try blank today :)
much better :) mite have to do the light strip mod next to light it up :)
Keep up the good work bud, was the ashtray delete an easy job?
Realy easy took me about 10 minutes start to finish, just stuck the radio on and started striping, the 2 8mm bolts tucked down the back of the grab handles where the worse be it get to :)
got a nice parcel today
my £20 to the door ebay bargain
now my engine bay is complete
was about to buy a abs pump repair but found something for my track car project on ebay that i would rather buy at the mo
How do I tell if I have the correct steering wheel module for cruise control without striping half the car?
I have assess to vcds at work
had some nice packages from tps today
Took me half hour to fit and 5 mins to code in and it works :)
It cost me £111 and some pence from tps
Reactions: irowpod
decided to debadge it today
looks so much better :)
Hey, im looking to de-badge mines but im worried about the faded paint around where the stickers are?
How did you remove all the sticky stuff?
U warmed the badges up with a heat gun and just pulled them off, then I used a toffee/caramel wheel in a drill to remove most of the sticky/black stuff then some compound Polish to finish it off :)
Reactions: shadow1993
whats a toffee or caramel wheel? :D
U can get one off eBay and all bodyshop supplier might even find one in b&q
