TTE500+ Upgrade Performance Turbocharger 2.5 TFSI TTRS 8J / RS3 8P/8V.1 / RSQ3 /RS3 8V
TTE Si
Site Sponsor
Site Sponsor
UK
TTE500+ Upgrade Performance Turbocharger 2.5 TFSI TTRS / RS3 / RSQ3
Introducing our TTE500+ performance turbocharger, Including a CNC matched and ported OE intake pipe for the 2.5 TFSI motor. Based on the original turbocharger but upgraded to new higher output specification. Offering The Complete Ultra Plug & Play Upgrade to over 500PS.
Engineered & Enhanced
At the core of our TTE500+ is a much larger TTE compressor wheel, chosen because it is highly efficient and creates an extremely high flow for comparative size. Re-Profiled compressor cover to optimised tolerance to ensure maximum compressor efficiency is given.
We CNC mill the exhaust turbine housing to accept a larger 9 Blade turbine and shaft.
Attention is given to CNC port the exhaust runners at the flange to match and smooth the transition from head to exhaust runner for maximum gas speed and so improving efficiency to the bigger turbine.
Special profile 360 deg high-performance motorsport journal bearing is fitted, to remain durable at higher loads with no loss in transient response. The actuator used is uprated sprung OE unit, fitted with our reinforced clamps for trouble-free operation. This also can also be modified to customer needs and specifications.
The intake pipe included with this upgrade has been CNC milled and hand finished to match and smooth the transition to the larger compressor inlet opening to lower turbulence and maximise velocity, this is sealed to the compressor cover by a Viton rubber o-ring for a constant dependable seal.
Equilibrium
Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
Key Points
TTE Billet Highly efficient compressor geometry with a 58mm Inducer
TTE 9 Blade high flow Turbine
Genuine BorgWarner Uprated & reinforced actuator
Genuine BorgWarner Reinforced motorsport bearing system
CNC Optimized and hand finished Intake pipe
Viton O-ring for Intake Sealing
CNC Optimized Compressor Cover Machining Clearances
CNC Port Matched Exhaust Manifold Runners
Plug and Play Installation
Single parts finely balanced then components assembled and core high-speed VSR balanced, supplied with a balance test result document
500+PS Capable (proven at over 550PS)
We can also offer to upgrade used good condition serviceable unit to TTE500 specification.
Pricing :
https://tteglobal.com/audi/rs3/8v.1-2.5-tfsi/28/tte500-upgrade-turbocharger
Top Tip : The original VAG Manifold gasket needs enlarging to match the ports on the turbo.
Reactions: MartayMcFly, s3_trev and Kelza
Tunetec TTRS TTE500 526ps 767nm 1.8-1.5bar
TTE500 Vs OEM RS3/TTRS 2.5 TFSI
Alastair's RS3 TTE500S By MRC Tuning 556PS 713Nm Special thanks for Image courtesy from AudiTuner.COM
Reactions: RedDejavu
TTRS TTE500 By Revo Romaina STG 3+ SOFTWARE 11.127 SEC 1/4MILE
Nice result from SL-Tuningsolutions with this RS3 using TTE500 Upgrade Turbocharger & CNC Iintake even with a stock exhaust and original downpipes with modification 506PS / 698NM.
Super Smooth Power with Great Response & Results from SZ-Performance
TTE 500 Turbo, Spec Stage 3+, Wagner Evo3 IC, Wagner Downpipes with sport cats
Stock HPFP, Stock intake, Stock exhaust
502PS / 597 Nm
Maybe a world first?
Complety Stock car apart from TTE500 upgrade turbo & Map . 500PS 680NM
AUDI TTRS TTE500 by SL-Tuningsolutions 0-300+ Km/H Sprint ! 100-200 6.74 corrected.
Car Spec info :
- TTE500 Upgrade Turbo
- HPerformance intercooler
- 90mm Intake
- 102 pump fuel
- SL-Tuning Software
- Stock exhaust system
- Stock HPFP
- Stock Car weight
(catless. no pre-cat, no main cat)
NICE TTE500 RESULTS.. 535 PS 732NM, 6.74 Seconds 100-200
Car Spec info :
- 90mm Intake
- 102 pump fuel
- Stock HPFP
- Stock Car weight
Nice power torque with around 500nm at 2800 Rpm !
RS3 TTE500 by TuneTec 100-200 and VMAX run
Result from SL-tuning
521PS/ 725 NM
At 3000 RPM, we are already at 500+ NM at 7000 RPM near also 500 NM
Following setup:
Original down pipe without pre cat
Original Exhaust System
TTE500 Turbocharger
Wagner-TUNING EVO 2 LLK
90 mm Inlet
Aral ultimate102
Vehicle is currently 100-200 in 7,7-8,1 seconds....
Next, is a upgrade HPFP
Results from last night at KSF 100 octane and WMI
RS3 412ps vs RS3 TTE500 511PS (Tunetec software)
Audi TTRS 2.5 TFSI TTE500 by Audi Bourguignon
TTE500 Turbocharger
Wagner Evo 3 intercooler
102 Fuel
Upgrade HPFP
JDEngineering Software
535PS 697Nm (528HP)
KSF MOTORSPORT TTRS TTE500 MRC Tuned
New update to the TTE500 upgrade we have improved the design and now we are cnc machining a slot and fitting a vitton rubber oring(will update picture set soon)
RS3 8V TTE500 with Real Time custom mapping by MTR Performance
TTE500 Turbocharger
Modified OEM down pipe
PPH intake pipe to OEM filter box
All rest stock. Upgrade inter cooler next..
528PS 690NM
Great results from KSF MOTORSPORT as normal using our TTE500 2.5TFSI Upgrade Turbocharger
- TTE500 Turbo
- Upgrade exhaust (de cat)
- Upgrade intercooler
- Upgrade HPFP
- Upgrade clutch & flywheel
- MRC Tuning Real time software
556.4PS 723Nm
Super result from MTR Performance Germany on this RS3 TTE500 at 561PS 742Nm !
Best to go on MTR Performance Facebook and ask questions. They speak perfect English
TTRS TTE500 M100 Software
520HP 620nm
Audi RS3 8P TTE500 By SLS Tuning (530HP 740NM)
Aoon's Audi RS3 8V has the TTE500 Turbo, large intake pipe, decat, Stock catback, Stock airbox, Forge FMIC.
With the MRC Stage3 Remap it did 506ps and 628nm on 99 ron fuel
On higher octane fuel but the 99ron tune it did 531ps 653nm
Aoon's RS3 TTE500 first 1/4 mile try 11.3@122mph
99 tesco fuel
full weight
street tyres
Hmmm.
506ps is a little low considering there's some nice mods on this car?
Maybe look at a bigger intake and bigger exhaust? And HPFP
Its not low but I think more accurate TBH and average. The turbo after all is 500ps unit.. Any more bonus and much to do with package. Need to remember to get 500 few years back you needed everything and more. Stock exhaust and stock airbox are limiting the number a bit too i feel.
Reactions: steve-tt
Audi TT RS 2.5TFSI
TTE500 Turbo and intake
Forge intercooler
VW-Racing Intake
Miltek exhaust
Autotech HPFP
Fuel is 50/50 sp98/e85
C2Motorsport software
541HP& 720nm
Audi RS3 2.5 TFSI 367pk.
JD Stage 3 remap: 539pk & 680Nm
Specs:
TTE 500 turbo
HPFP Upgrade
Milltek full exhaust
Forge intercooler
JD Stage 3 remap
RON102 Fuel
TTE500 result from Ksf motorsport
519PS 695NM
Bar-tek Motorsport RS3 TTE500
Engine specs: TTE500 Turbo, Mahle pistons, BAR-TEK conrods, Edel exhaust system
551PS 682Nm
