Seat Leon Cupra TTE420 by Madness-Motorsport 430PS 540NM (NO WMI)
Engine:
- ECU custom remap: Stage 3 by Madness Motorsport
- The Turbo Engineers TTE420 Hybrid Turbocharger
- Diverter Valve Revision D, Go Fast Beats DV+
- Audi S3 OEM Intercooler, Wagner Tuning
- Spul Engineering Turbo Outlet Pipe Kit
- Neuspeed Hi-Flo Air Charge Pipe
- Forge Motorsport Twin-Take Induction System (wrapped in gold Mishimoto heat defense reflective tape)
- Forge Motorsport DV Hose
- Forge Motorsport Catch Can
- Autotech Hi Pressure Fuel Pump internals
- Audi RS3/TTRS OEM Low Pressure (in-tank) Fuel Pump
- Audi RS4 OEM Fuel Rail Pressure regulator Return Valve
- NGK Iridium BKR7EIX, NGK Laser Platinum PFR7S8EG, NGK Iridium BKR7EIX
- Audi R8 OEM Ignition Coils (revision E)
- Coil Pack Wiring Harness (Conduit) Red
- Horschel Motorsports Fluidampr Harmonic Damper
- BSH Pendulum Mount Kit + Torque Mount, Spul Engineering Dog Bone Engine Mount Kit (Street)
- Torque Solution Engine Mount, Golf R Mk6 OEM Engine Mount
- Audi TTS OEM Engine Cover
- Audi R8 OEM Engine Oil Filler Cap
- Porsche 991 OEM Coolant Expansion Tank Cap
- Motul 300V Power 5W40 ESTER Core® Racing Oil
- Motul Inugel Optimal Coolant Anti Freeze
Exhaust:
- Supersprint 100% Stainless steel system Oversize Ø80mm ⇒ Ø70mm ⇒ Ø65mm
- Leon Cupra 1P OEM
- Supersprint 100% Stainless steel "Racing" system Oversize Ø76mm
Gearbox ( Transmission):
- ZF Sachs Performance Clutch Kit + Single Mass Flywheel
- MFactory Helical Limited Slip Differential
- ARP LSD Bolt Kit
- Forge Motorsport Short Shifter, OEM
- USP Motorsports Stainless Steel Clutch Line
- Transmission OEM Shift Forks Modified (1st-2nd and 3rd-4th gear)
- Torque Solution Transmission Mount, Golf R Mk6 OEM Transmission Mount
- Motul Multi DCTF Gearbox Oil
Steering & Suspension:
- Bilstein B12 Sportline kit (Bilstein B8 shock absorbers + Eibach Sportline performance springs)
- SuperPro Anti Lift & Caster Increase Alloy Bracket Kit
- OEM Front Sway Bar End Links modified (shortened)
Brakes:
- (Front): Alcon Advantage Extreme brake kit: 6 pot monobloc callipers & carriers (painted in Foliatec Racing Rosso), Ø365x32 mm crescent grooved floating discs, Ferodo DS Performance brake pads, HEL braided brake lines
- (Rear): Golf V R32 OEM brake callipers, carriers (painted in Foliatec Racing Rosso) & dust shields, Alcon OEM size replacement crescent grooved discs 310x22 (Golf V R32/Golf VI R/Audi TTS...), Ferodo DS Performance brake pads, Goodridge braided brake lines.
- Motul DOT 5.1 brake fluid
Wheels & Tires:
- (Summer): Leon Cupra R 1P OEM Ronal Potenza 19", Goodyear Eagle F1 Asymmetric 235/35 R19, Michelin Pilot Super Sport 235/35 R19
- (Winter): Leon Cupra 1P OEM Ronal Orion 18", Goodyear Ultragrip Performance 225/40 R18
- Spul Engineering Wheel Spacer Kit (10mm front - 10mm rear)
- Extended corrosion resistant Conical Seat Lug Bolts
Exterior:
- Hella Tail Lights Smoked
- Philips Silver Vision indicator bulbs
- Excelite H3 Xenon White Halogen fog light
- RFB Lighting City Light Led Conversion, Front position aftermarket LED
- LED license plate light
- Peugeot 607 OEM Aerial
- LED dark smoked side blinkers
- Golf Mk5 rear wheel arch liner splash guards
- Stebel Nautilus Compact Truck Air Horn
Interior:
- Armrest OEM
- Defi Racer Boost Gauge White 60mm
- Audio Sources DVD Multimedia + reverse camera
- Magnat Edition Four Limited Amplifier 1200W
- Hertz Energy Speakers ECX 690.5 front 300W
- Hertz Energy Speakers ESK 165.5 rear 300W
