I'm not sure that 16" rims will fit on the 184 I don't think they will clear the brake callipers.
Has any one done this yet?
Do the brake calipers differ amongst models then? I know the S3 has a bigger set up, but I thought the front and rear discs and calipers were universal amongst all other 8V A3s.
Did you check the sticker on your drivers door?I'm interested in the answer to this as well. Need to know if I have to sell my 16" winter tyres and get 18" instead
Has anyone yet been able to establish whether 16" wheels will fit the 8V and whether the brake calipers differ between any trim levels/engines other than the S3?
I had 16" alloys with conti winter contact ts850's on last year, on both a saloon and hatchback. Both were 2.0 tdi 150's.
The alloys were from a Audi a3 8P offset was et50 so no different to the 18" they replaced.
The same alloys will be going on again in a few weeks time, winter is already looking close here in Aberdeen.
Just ordered 4x 205/55/R16 91H TS850s for our A3 today. Are they as good as the reviews suggest?I had 16" alloys with conti winter contact ts850's on last year...
Are we all expecting heavy snow this year?!
Well I've pressed the button on an Audi OEM set of winter wheels. I was tempted by some cheaper [after market wheel sets but the specs were 7.5" wide with tyres 225/45 R17 (I admit I wanted 17" rather than 16" wheels purely for looks). I wanted narrower wheels (better for cutting through snow) and the Audi set is 6.5" width with 205/50 R17 tyres so 9% narrower than my 18" standard wheels and 14% taller in sidewall height. As my car is a keeper I can justify the extra cost. The wheels are shown below and are 5-spoke Helica design - nice and easy to keep clean in the winter. They come with Dunlop SP Winter Sport 3D AO tyres which seem to be reviewed pretty well.
So now I think I have ensured that this winter (and all subsequent ones) will be the warmest on record with not a single flake of snow!
I already ensured this last year. I was all set with my Quattro and winter tyres and never saw a flake of snow all season. Worked well in the cold and wet though.
BTW, is it a solid theory that narrower tyres are better as they cut through the snow? I'd heard this too for summer tyres in snow but that winter tyres work better with a larger footprint that allows the special sipes to do their thing better. At the end of the day I guess there's not much discernible difference. Any thoughts out there?
I can't reply definitively but a few quotes from the Internet:
So, totally confused, I went with the "skinnier is better" theory but I'm sure there are people out there who have a better understanding of slip coefficients, static versus sliding friction, aquaplaning formula, tractive force, propulsive force, wheel slip angles and a million other things that I can't spell let alone understand.
- Narrow tyres are better in snow as they distribute the car's weight over a smaller surface area. Thus the force exerted on the ground will be greater at any given point on the contact patch of the tyre. It is the opposite of this that explains why people wear tennis rackets on their feet to stop them sinking into the snow. A car with skinny tyres tends to slice through the snow, whereas the garden-rollers on a porsche will tend to slide along the suface, like an eskino with tennis rackets!
- Manufacturers specify narrow tyres/small wheels for use in the snow, not just to cut thro' the snow but to allow the fitting of snow chains without destroying the wheel arches.
- Unfortunately wide, low profile tires have to "plough" a wide path through deep snow, where narrower tires have an easier time. So if you're likely to drive through deep snow this year, you'll want winter / snow tires and wheels in sizes that help put the laws of physics on your side.
- It depends mostly on the type of snow you generally have in your area. If it is very cold and you have mostly powder snow, then narrower tires would be your best bet because it will push the snow out of the way much easier. Powder snow on the highway is most often associated with the appearance of dust in your rear view mirror. BTW, if the temperature is very cold and you have powder snow, it is very hard and sometimes impossible to make a snowball...it just falls apart when you let go of it.
- If on the other hand, you get mostly wet snow (makes a snowball easily and tightly) a wider tire would be your best bet since it has more channels in the surface with which to grip the snow. Since it is wider, it will also tend to ride up away from the ice formed on the roadway itself from the compacted snow of other drivers.
... who knows. Though the tyres discussed here could be better named 'cold weather tyres'. And I am expecting some cold weather this winterAre we all expecting heavy snow this year?!
One of the problems with snow tyres is that they give me the confidence to drive in all conditions. The problem is other cars, without winter tyres, sliding all over the road in bad conditions. Have had a few near misses and wished I had stayed at home.If we have heavy snow I try not to drive at all. I still put winter tyres on, just not with snow in mind.
I haven't decided what to do about winter tyres yet.
Last year I had a full set of old scabby alloys with mid range 16" tyres on my 8P. Now I have an 8V and don't really want to put the scabby 16" alloys on. With it being front wheel drive only could I just get a pair of 18" and leave the rears with the original tyres on?
Recommendations greatly appreciated
Phil
I'm no expert but I would imagine that this combination would be incredibly unstable. It is never sensible to mix tyres. You are obliged to inform your insurance company when fitting winter tyres - like any other change. I'm with LV and they are quite happy with what I told them and there is no change to the premium. I'd have been miffed if there had been when I'm fitting a safety feature.
No Phil I did understand - but summer tyres on the rear and winters on the front would be a disaster waiting to happen. All the grip would be on the fronts so you'd get massive oversteer (or did I mean under steer?) anyway your rear wheels would be trying to catch your fronts! .
Thanks I misunderstood
Ok in that case I will get some 16" SE rims and reuse my tyres.
For 16" wheels Audi recommend H speed rating for winter tyres.
I imagine it will be similar for 17" wheels.
... exactly. I think the correct term is snap oversteer. It scares me that many of the women at my wife's work, think it is ok to fit only 2 winter tyres. I hope I am never passing a junction they are trying to stop for in the snow!No Phil I did understand - but summer tyres on the rear and winters on the front would be a disaster waiting to happen. All the grip would be on the fronts so you'd get massive oversteer (or did I mean under steer?) anyway your rear wheels would be trying to catch your fronts! .
I'm in a similar situation. I bought some old 16" alloys for winter tyres. Not only do the alloys look rubbish on the car, they are also wearing the tyres unevenly.Ok in that case I will get some 16" SE rims and reuse my tyres.
Where did you find this info please?
