Hi All,
New to this forum, I thought I would post up my experiences with S4 ownership and hopefully can help people with questions on the S4 to help out.
I thought it was time I had a look through all my invoices on what I have spent on the S4 since I purchased it back in Sept 2012 with 95K on the clock. I mainly got it as a weekend car and also to do bits as a hobby.
Here is a list of the service history and costs/ most of the work was carried out by myself to save on huge labour costs, I noted where Audi did the work. I didn't include MOT's or petrol on top of this cost & any tarty bits like painting the calipers etc oh and the amount of wax/ cleaning materials I have used in the past 2 years! I thought this might help anyone looking for an S4 or currently owning one on rough costs
Here is a pic of when I first got the car back in Sept12 after a good clean up
PDI â Peter Gilder Audi, Sheffield â 26/06/03
16691 - Peter Gilder Audi, Sheffield â 23/09/04
33153 - Peter Gilder Audi, Sheffield â 23/09/06
50155 - Peter Gilder Audi, Sheffield â 16/05/07
63492 â Basingstoke Audi â 25/09/08 (used car MPC)
78862 â Newbury Audi â 22/07/10 â (used car MPC) spark plugs/ air filter/ pollen filter/ rear suspension bushes/ Intake manifold (£1400)
30/5/11 -Coil packs (Audi Recall)
87983 â Swindon Audi â 31/10/11 â (Timing Chains/ tensioners/ Clutch & clutch slave cylinder & headlight switch/ Aircon regas/ coolant change & 4 wheel alignment & Service) £3680 â Audi Warranty
I Purchased the car Sept 2012, 95K on the clock
22/09/12 â Airbag connector/ under driverâs seat - £14.40
96652 â Swindon Audi â 09/11/12 â Rocker cover gaskets both banks - £296.29 â Audi Warranty
96664 â Own Service â 10/11/12 â Oil/ filter/ Air filter/ pollen filter & Wiper blades £124.66
97600 â Gearbox/ Diff oil change 02/03/13 â Motul 300 75W90 ester based racing oil - £67.96
97800 â Fitted Milltek Non res cat back exhaust £440
98120 â NS/OS front upper suspension arms + drop links - 20/04/13 - £195.82
98280 â Rocker cover passenger side due to leak + cleaned breather system 23/04/13 - £45
98330 â Alternator belt/ Tensioner & Idler bearing + Snub Mount â 04/05/13 - £132.36
98550 â Coolant temp sensor â 05/06/13 - £61.81
98660 â Aircon sanitizer + pollen filter â 11/06/13 -£33.06
98884 â Front discs/ pads â 06/07/13 - £194.17
99200 â Engine mounts both sides/ ARBâs & starter motor â 01/08/13 - £561.09
99446 â Own Service 13/08/13 â Oil & Filter change/ Spark plugs/ Brake fluid â £103.80
99529 â Audi Swindon â 16/08/13 â Water Pump/ Thermostat/ Coolant expansion bottle & Coolant change - £410.58
22/08/14 - Rear Headlight cover + plastic trim underside £26.10
29/10/14 -4 x Wheel refurb/ powdercoat £254.40
101784 - Changed rear flexi brake hose + Brake fluid change -21/05/14 £41.97
102349 â Own Service 2/08/14 â Oil & Filter change + Pollen filter £80.66
I have also painted the door blades/ colour coded them to the car also sorted out some rust behind the door blade £40
They came out really nice
| On the service I checked over the underneath/ engine and seems spot on no oil/ coolant leaks and pretty clean. The only things planned for the future will be to possibly change the front brake hoses, they look ok but have some ready to be fitted. Maybe set of rear discs/ pads and fix the Lumbar support, found the source of why the airbag light kept going off after moving the seat around. The bar on the lumbar support had snapped and was rubbing against the airbag wire in the back of the seat. I have put together a temp solution which works nicely but could be a job for the winter as I can take the seat out and sort it out in the house MOT is due this month... so fingers crossed all is ok and passes no problem. Cheers Al |
