DPF pressure sensor fault after aborted remap
nickybeal
Hi Guys
I have a 2011 2.0 tdi (140) s-line,Had a fella remap the ecu,on fitting the ecu the car wouldnt start or recognise the ecu,so he returned to the workshop,replaced my original map and tried again,still no joy.He went away and left me his wife's 3 series and returned 2 days later with the ecu and it worked,apparently it was stuck in boot mode for some reason,never had this before!
he has unlocked the ecu to accept remap by obd port now,and will have car for a day when he returns from hols.
all was running fine,no lights on etc,until I got home,pulled onto the drive and PING up came the EML,got a mate to plugin vcds and it come up with DPF Pressure sensor short to ground,he reckons no fault with sensor must be something matey has done to ecu.
what do you guys think?
the car is running well,went for a run on the motorway see if i could clear the dpf,but not sure if it has done anything.
Guy should have known that anything post 2010 and he's taking the ECU out of the car to map it
It could just be coincidence, it does happen
Whats unclear from your post is if the light is still on? Was your mate able to clear the fault? Or if he did, did it come straight back?
Guy should have known that anything post 2010 and he's taking the ECU out of the car to map itIt could just be coincidence, it does happenWhats unclear from your post is if the light is still on? Was your mate able to clear the fault? Or if he did, did it come straight back?
Guy was aware ECU had to be removed and mapped on the bench,has all the kit to do itNever had the non start problem before and had to send ECU to guy with better equipmentTo find chip stuck in boot mode,ECU now unlocked to accept remap by obd Yes my mate cleared code but popped on again after 3 miles and still on
Started the car this morning and the light has gone out Happy days
so all set for the remap on Monday
That light has come on for a reason and shoukd have stored a fault code within the ECU. Hopefully your mapper will carry out a full diagnostic check prior to the remap. If something is amiss the remap will cause you problems.........
What was the fault code your mate found?
EDIT - just seen it. Get your mapper to log the sensors prior to the map to make sure they are reading correctly
if one of those is faulty it will lead to DPF problems in the future; even more so once mapped.
BUM ! EML back on this morning,got a cable and plugged in showing pressure sensor again,disregard other faults,was when the remap trouble and ecu not communicating (stuck in boot mode)
have got a new sensor and will fit soon,
Thursday,17,July,2014,14:08:26:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8P7BA110721 License Plate: CV11 PTZ
Mileage: 123860km-76963mi Repair Order: 17-7-14
Chassis Type: 8P (8P0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 61 77
VIN: WAUZZZ8P7BA110721 Mileage: 123860km/76963miles
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 AB HW: 03L 906 018 AG
Component: R4 2,0L EDC H20 5394
Revision: 41H20--- Serial number: AUX7Z0K0FNO06S
Coding: 00190012040501080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018AB 003005
ROD: EV_ECM20TDI01103L906018AB.rod
VCID: 6ADB24238D8A324E2A7-803F
2 Faults Found:
12002 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
5262 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [174] - Short to GND
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 136
Mileage: 123731 km
Date: 2014.07.10
Time: 00:07:21
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 13424012092300FAC81202E6901A0092380800
VCID: 76E30053C132E6AEBEF-8023
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 123713 km
Time Indication: 0
Date: 2014.07.09
Time: 19:07:23
Freeze Frame:
Count: 0
Count: 2
Count: 20736
Count: 8194
Count: 43520
Count: 0
Count: 254
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0170
Revision: 000154 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78FF0E6B0B2690DEAC3-802D
1 Fault Found:
01177 - Engine Control Unit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 215
Mileage: 123713 km
Time Indication: 0
Date: 2014.07.09
Time: 19:07:23
Freeze Frame:
ON
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 G HW: 8P0 907 063 G
Component: BCM PQ35 M 107 0615
Revision: 00107 AF
Coding: 4E000A2FA005F000207041E00000094C421E25AA204DD12AE4008F840041
VCID: 387FCE6B8BA650DE6C3-806D
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 16
Reset counter: 215
Mileage: 123713 km
Time Indication: 0
Date: 2014.07.09
Time: 19:07:24
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
Term 50 On
OFF
OFF
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FB00A2GJX
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FAD95B71628F7665D9-801A
Crash sensor for side airbag; driver side:
Serial number: 34928RB400005F937E3
Crash sensor for side airbag; passenger side:
Serial number: 35028RB400005F937BD.
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB400005F94127I
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB400005F9437DW
Crash sensor for front airbag; driver side:
Serial number: 35547RB40000601726EG
Crash sensor for front airbag; passenger side:
Serial number: 35647RB4000060172300
No fault code found.
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004012
VCID: 4683B0933152362EEEF-8013
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 H HW: 8P0 920 982 H
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 2240K004011511
Coding: 0260428
Shop #: WSC 00011 888 96745
VCID: 3E73D87369826EEEA6F-806B
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 8P0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H43 0311
Revision: H43 Serial number: 160111F2002063
Coding: 350101
VCID: 3365F94792C0B386591-8066
2 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 215
Mileage: 123714 km
Time Indication: 0
Date: 2014.07.09
Time: 00:00:50
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 123532 km
Time Indication: 0
Date: 2014.06.28
Time: 14:18:11
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0131636
VCID: 4999BBAF204CD95603D-801C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 233 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 215
Mileage: 123713 km
Time Indication: 0
Date: 2014.07.09
Time: 19:07:24
Freeze Frame:
Voltage: 12.38 V
DU
Temperature: 22.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0131636
VCID: 4A9B84A3254AD24E0A7-801F
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: 3C77D27B7F9E7CFE88B-8069
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 123720 km
Time Indication: 0
Date: 2014.07.09
Time: 19:07:22
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005270723
Coding: 0001222
VCID: F4E7BA5B974E74BE00B-80A1
2 Faults Found:
02503 - Output Wire to Radio
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 155
Mileage: 123532 km
Time Indication: 0
Date: 2014.06.28
Time: 14:18:16
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 67
Reset counter: 191
Mileage: 123532 km
Time Indication: 0
Date: 2014.06.28
Time: 15:10:22
End ---------------------------------------------------------------------
I would say its not been mapped correctly or they have forgot to map something out which the car is still trying to trigger,i have heard of a few situations like this and others where people have had DPF's removed but the car regen cycle hasn't been taken out.
I believe the OP still has the DPF in place??
When replacing the sensor make sure you calibrate it. It needs to be done BEFORE you switch the engine on I believe. I think Ross Tech have a guide for fitting a new sensor
yes DPF still in place,should be on my stock map,possibility has someone elses stock map
Thursday,17,July,2014,15:17:58:62939
Mileage: Repair Order: 17-7-14 a
Address 01: Engine (03L 906 018 AB)
15:17:28
290 Particle filter; oil ash volume 0.03 l
291 Particle filter; soot mass calculated 9.01 g
292 Particle filter; soot mass measured -0.15 g
293 Particle filter; time since last regeneration 8783 s
After a bit of confusion and searching I have got a G505 sensor,not sure if this is the correct one? everyone goes on about G450 which I cant find on any diagram
