DIY: Rear Open Sky Sun Shade Latch Repair
fateman
I bought my sportback back in January and it came with broken latch on the rear sun shade, which didn't annoy me that much as I am only sitting in the front and the replacement bow would cost me 120€ which is outrageous to say the least. However I want to have my car in fully functional condition so I gave it a shot and it was a success :)
It is necessary to say that this repair is not applicable for everyone as the way the latch snaps is different every single time. What I would like to present is a solution I did on my car. You can get the idea how to proceed and see that it is not that difficult in the first place.
First you need to remove the sun shade bow from the rails. To do this you just pull one side of the shade towards the end so that the bow is positioned diagonally across the roof window. After that just push one side up to free the bow, then to the same with the other side and you have a bow freely hanging in the cabin.
IMG 20140628 142208
After that pull off the sliders from both sides. they are not fastened in any way just use some force and they will come off.
IMG 20140628 142131 50
Once they are off open the rear door or lower the window and slide the bow out of the curtain. At this point you want to have some kind of clip ready to secure the curtain and prevent it from rolling inside the roof at which point your job would get much more difficult. I used a clip we use in kitchen to close open flour or cereals so they don't get damp.
IMG 20140628 141955 50IMG 20140628 142006 50IMG 20140628 141559 50IMG 20140628 141451 50
At this point you have a bow that we can further work with. Lock your car and go to your work room.
First thing to do with the bow is to separate the plastic part from the aluminium bar. Those two are glued together with some sort of black silicone. The way I did it was to take two small screwdrivers and pry it apart bit by bit, do not rush it or take large chunks as you might get lucky and break the thing. As you can see the plastic cover is glued by a silicone in the groves of the aluminium bar. Do not remove the silicone, you can assemble the two parts again without reapplying the silicone and it will hold as good as before.
IMG 20140627 213947 50IMG 20140627 213829 50IMG 20140627 213922 50IMG 20140627 214251 50IMG 20140627 214315 50IMG 20140627 214258 50
Next step will be to disassemble the latch itself from the plastic bow. Latch holds in place by being pivoted around two small plastic shafts. you will need to free the latch from these. Be extra careful as they can snap easily. This was the most critical part of the repair in my opinion. You are left with the little sucker that costs 0,00001 cents to manufacture, however in Audi they decided that the best repair solution would be to replace the whole bow that costs 120€. Genius!
IMG 20140627 214405 50IMG 20140627 214345 50IMG 20140627 214659 50IMG 20140627 214738 50IMG 20140627 214627 50IMG 20140627 214638 50
At this point you are going to improvise as I said at the beginning every snap is different. For inspiration below is a solution I used.
Simple solution would be to glue some piece of plastic with super-glue and wait for a week for it to snap again. I have on the other hand used a piece of aluminium sheet which after some tedious sawing, drilling, grinding, bending soldering and painting looked like this. Just to note, make sure that any parts you use are not blocking the mechanism so that you are able to open the latch once assembled. the Aluminium bar also restricts the usable place, so note the dimensions before disassembling the bow.
IMG 20140628 124139 50IMG 20140628 124127 50IMG 20140628 124118 50IMG 20140628 125030 50IMG 20140628 125052 50
Once put together the bow looked like this. (I forgot to take pictures of bow with the aluminium bar, but you get the idea.)
IMG 20140628 140536 50IMG 20140628 140551
All you are left with is to install the repaired bow in to the car. Installation is quite simple, just reverse the disassembly process. Slide the curtain out. Remove the clip from curtain. Slide in the the bow on to the curtain. Put on the sliders. Install the bow in to the rails. Test the latch and have a beer or two because you have just saved 120€!
IMG 20140628 142315 50IMG 20140628 142643 50IMG 20140628 142640 50IMG 20140628 142530 50
Hope this helps anyone with a similar problem ;)
Reactions: paul_bfree
Just an idea but I would have tried using this to 'rebuild' the broken part. Costs less than a tenner for a pack of 5 (25g) which should be enough to do this. It is very strong and I've used it on all sorts of broken plastic bits with great success.
sugru - the future needs fixing - sugru
That would probably work as well, however I did not even know something like that existed :) I was trying to fix it with whatever I could find at home. Good idea though, I might use it next time something breaks :) Thanks
Fateman, thanks so much for your detailed photos and instructions. I had some clue about removal of the sunshade bow, but not about removing the clip from the bow.
I'm hoping your fix is still working. Your solution uses an interesting piece of metal... but I'm wondering if it would hold up OK, as the metal would be exposed to the sun and heat up. That heat could cause the glue holding it to the plastic to weaken and then the metal would detach at some point. Hopefully that didn't happen and that your repair is still holding, nearly 3 years later.
My rear sunshade clip broke last year and I've just left it as-is, because the dealer had told me a price for the whole shade roller plus bow... which was a major put-off cost. So good to know that the bow is actually a separate part that can be ordered. Oddly, the black version is a good $30 cheaper than the colored versions. Well, if you don't mind a small color difference, you can buy the cheaper bow, then just replace the clip portion... :) The bow would be original and the clip itself would be black.
I used an excellent glue called Marine-Tex, which is a two-part epoxy that is incredibly tough, water resistant, and crack resistant. I've used it for many, many projects successfully. My clip broke off in one piece that I glued back into place (snapped off from each of the two small plastic "arms", so the gluing required the two attachment points). And it worked for a few days... until the plastic piece ("cross bar") snapped in half and the torque caused the two pieces to pop off (breaking away from the Marine-Tex). Your metal reinforcement is definitely the way to go. Somehow Audi used an inferior plastic that, after sufficient sun exposure, begins to weaken. My shade stayed closed most of the time, so it wasn't due to repeated clipping into place. This is why the clips break, and why trying to repair the original plastic fragment is futile. You do need to provide a substitute material. I'm hoping that from what fateman demonstrated, the plastic "arms" are more solid further back, as they are out of sun exposure. So the substitute material doesn't need to be fashioned as a complete substitute for the entire length of the arms.
As luck would have it, I have a pair of Nautica shorts that have these annoying metal buckles on the sides for "cinching up" the shorts for someone with a more narrow waist. I'd decided to snip them off, but rather than throwing them away, I tossed them into my "junk drawer", which is a repository for all kinds of random components from a myriad of things. As I looked over fateman's repair, somehow I remembered them. They're made of metal, but thin enough that I should be able to use clippers to trim them into a replacement part for the sunshade bow clip. I measured them up and they're "just about" the right width for this application. I'll follow up soon with some photos and the attempt.
[NOTE: I would say that my sunshade clip lasted about 7 years, with minimal physical use -- it just snapped due to sun exposure. I recalled seeing some people experiencing the breakage within warranty, so they got them replaced. Even if the newer clip on an OEM replacement bow is somehow made of a sturdier plastic, there is still the inherent issue of sun exposure. Of course, not really a concern for these older cars, if someone isn't planning to keep their A3 for more than a few years. But if I'm forced to go that route, I would probably put some covering over it to minimize degradation from the powerful rays of the sun. Like aluminum tape.]
The first set of photos shows the original clip and the metal buckle to repair it. I eventually glued them together using Loctite Epoxy Plastic Bonder. I sanded down the smooth shiny plastic surfaces in hopes of creating a better bond this time. It ended up a thicker application than I expected and wouldn't fit in place (the two pegs for the pivot wouldn't clear when trying to insert the clip into place), so I had to sand it down a bit. But I managed to get it into place. It looks pretty good. Tomorrow I'll be testing it out installed, after a full 48 hours of curing... and see if it holds up to the increasing warm temperatures. The last image is a composite... top half showing how I kept the shade from rolling back inside (used two small super strong spring clips from Home Depot: one to the left side, one to the right side), and bottom half showing what it looks like installed. It looks better in person. A test fit proved that it works and attaches to the clip mounting in the roof. I'm going to leave it unhooked for another day, for added curing... just in case.
NOTE: The black "gunk" you see traces of on the clip is from the Marine-Tex that I had to break off after the first repair failed. I didn't use the Marine-Tex again, as that stuff works best in larger amounts. For this small application, I figured that the Loctite Epoxy Plastic Bonder would be better. In a few positive reviews I'd read, people had successfully used it bonding plastic and metal.
more than loclite or putting aluminium stuff you could ask some of members to 3d print it for you or plastic welding (would look a lot better)
It actually looks fine installed. You don't notice anything different unless you really look at it up close. My main concern is for it to last. And so far it seems to be holding up well. The Loctite Epoxy glue is very durable. My hope is that it will last at least a few years. If I had to repeat the same repair 3~4 years from now, it won't be a problem -- I know exactly what to do. But then, who knows -- I may no longer be the owner by then.
Hello, everyone! Fast forward 6 years later… I have the same problem and despite spending 2 hours researching for a way out, I am back to square 1. The only option seems to be buying a new piece that is around 160€. Doesn anyone have a better solution that could share it with me?
So my problem is that the latch of the rear sunshade broke. Model name: Audi A3 8P from 2008
I remember someone said a 3D printed version would be possible. But I couldn’t find anything like that.
My gluing solution ultimately failed again. I was tired of doing this every 6 to 12 months, so I just bought the sunshade arm assembly. Given how long it took for the original one to fail, I'm pretty certain I won't be the owner for the next time it fails. Yes, it's pricey... I think I paid $120 USD. But in the end, it's worth it. Peace of mind.
I don't know if sun exposure is a contributor to the problem... but if you do tend to park in the sun a lot, it might be worth applying aluminum tape to the plastic clip portion to shield it from UV.
For what it's worth, the image hosting site I had linked earlier above changed their URL references... so all of the links are broken and this site won't allow editing of old messages.
Here are the image links, in case anyone wants to see what I had tried to do:
Hello, I have the same problem. I bought a few weeks ago Audi A3 and the button in handle on sky roof is broken. I can't find the original parts, so I don't know how can I repair it. I have 3D printer. Do you have anybody the file on 3D printer or original parts with sizes.
Thank you.
Thank you.:blush:
Hey! Sorry to hear about your Audi A3 sunroof button issue frustrating for sure. If you have a 3D printer, you might find someone who’s already modeled it, but I don’t have the file myself. Try searching Audi enthusiast forums or Facebook groups for a CAD/STL file. You could also measure the broken piece and design your own if originals aren’t available. Good luck
