thetrashcanman
Hi all, just bought some R8 calipers for my S3, but am wondering what discs I can/should pair with this and where to get them from, any help is greatly appreciated
I had 362mm AP Racing 2-piece discs on with mine, and you'll need custom mounting brackets to fit the calipers.
The brake guru is Daveb1970. He sorted me out with a set of AP Racing 362mm x 32mm discs and fitting kit for my R8 brakes, which is the caliper carriers and associated bolts. In reality you'd be lucky to get away with them under 18's, but it's possible and they would need to have a pretty low offset and a straight spoke pattern. I had 19" x 8.5J MTM Bimotos with ET50 and they fit well under those. If you can't get hold of Dave, perhaps send N8 a PM as he can get source the required parts for you also.
Hope this helps.
Paula![]()
Dave is often very busy,so he may take some time to get back to you,but he is THE man.
Give Alex at AKS a call:
ABOUT - AKStuning
He deals with the retail side more for Dave now or so im told when I called a few weeks back.
Yeah, DaveB made my carriers too. The R8 brembos will (just) fit under the standard S3 18" wheels with spacers on as the spokes will foul on the caliper with the standard offset.
