Audi S3 8P3 with the usual mods...
yes mate, you just need to change the code and adaptation via vcds and you're good to go...
Reactions: Pergan
Aight! But why did you mess around with the reverse light?
I'm gonna give my car some eyes in the back as well, and I think it's to expensive with rear sensors.
The camera will fit well with my RNS-E retrofit.
Damn dude! You've got serious skills, amazing build thread.
Reactions: grchmason
once i installed the 5mm spacers i thought i'd get the alignment checked to see if i could get any more camber out of the front. the suspension shop said its pretty well set up for road and occasional track use so i thought i'd leave it alone. he did slightly adjust the rear toe...
once i got the car back home i gave the inside a quick clean after my recent rooting around installing stuff. not much more to do now; illuminated bose speaker grilles and s3 glove box handle, illuminated switch for water meth on/off and illluminated switch blank for status light, also toying with the idea of a gauge for water meth flow meter. not sure whether to install the gauge in a vent pod or replace the boost gauge on the steering cowl. i'm not really a fan of the cowl gauge at the moment as it doesn't look much like an oem install...
Reactions: grchmason, shadow1993 and Pergan
my resistors showed up so i should be able to get rid of that horrible bulb out warning...
Beautiful car, and you sir are one clever dude.
Reactions: Andru8
i had a couple of days during my last break to do it a bit more to the s3, i finally got these made up to ensure my wheels clear the rs3 brakes. pretty hard to tell they are there i reckon...
i then decided to tackle wiring up my push start as i only had time to install the switch last time. not many photos unfortunately, first requirement is to remove the steering wheel...
a snap of the connection to the rear of the ignition barrel. for anyone planning to do the same mod the wires which require switching are the yellow and red ones...
while i was in the mood and things were going well i decided to install the s3 and 4 rings switches which i will use for my w/m set up. s3 push button for on/off and the 4 rings for the wm status light...
finally a quick vid of the push start in action...
once it was all complete i gave the car a wash and wax before i took it for a run to the pub. i also wiped the engine bay down and was surprised how well it came up so i took a photo...
a photo from the pub carpark...
the hybrid arrived in the post yesterday so should hopefully see more power in the new year...
and finally another shout out to my contact at audi for coming through with fuses i was chasing (a couple of fuses in the fusebox were a different type and my ocd couldn’t handle it) and he threw in an mmi cable for good measure, top man...
Reactions: Alex_Wil, grchmason, KentKid and 1 other person
I think someone's looking forwards to a busy Xmas.
I see you've also enlisted a mechanic for those difficult to reach places...pic 7!
nice idea but with a brain the size of a pea that thing wouldn't know one end of a spanner from the other. the only possible chance i'd get of some help would be if the tools had food strapped to them...
Reactions: S3Alex
wow, amazing mods on your car, and beautiful, i need to know about the start stop push button.. i saw on your first pictures that you have the hole for the key(standard for everyone) ..in fact you need to put the key, turn fwd to put the contact and the pushbutton is only here for the start/ignition..? and for turn off the engine still the same (push on start button or just turn back the key) ?? if you have the Part number for the part with the start pushbutton i'm interesting?
very beautiful mod
Mine would just eat the spanners.....
Reactions: guile
i need to know about the start stop push button.. if you have the Part number for the part with the start pushbutton i'm interesting?
thanks mate, its just a start button, no stop. yep you have to turn the key to ignition on before pressing start. most people aren't a fan as its an extra movement in the system but i like the way it looks and i'm not in that much of a hurry to start my car...
i'll dig the part numbers out when i get chance but think they are included in this guide...
http://audiretrofit.quinlivan.net/rs4startbutton
nothing special but for some reason i like it. my mate grabbed his camera off the passenger seat to take a photo of the pub and i noticed the s3 in the shot when i was flicking through his photos. i wish he'd closed the door...
You sir have a wealth of knowledge and a very deep wallet by the looks of things...
Hadn't caught up with the thread in a while and thoroughly enjoyed reading all the updates... I'm actually going to do the aerial amp upgrade soon as I too have an otherwise error free car and the ocd is going crazy...
I remembered you had done it and came to the thread for some tips...
I'll need to do some more research tho as i'm still in the dark as to much much exactly its going to cost me... My money well has well and truly dried up ;)
thanks mate, the knowledge comes from a lot of forum reading and research...
ebay could be your best friend when sourcing the amp and other parts. i got my amp second hand from ebay usa and the smaller converter (or whatever it is) directly from audi, about $50...
decided with the new turbo and new tune i wanted a shop built hpfp so gave hPa a go...
Hi Guile
Were did you get your bonnet bra from for your car?
Alex
So you went for the hybrid??? Good decision. I've had mines fitted.... take a look at my build thread for the results.
You'll be very happy with them..;)
thanks mate, i'll have a read now. i just ordered my wm kit yesterday so looking forward to installing that soon.
i'd like to pm you to get your feedback on nozzle sizes if thats ok, like wise i'll share my results with you once i've installed mine. i'm installing at the throttle body and charge pipe...
glad to hear i'll be happy with the results, pretty excited to get it fitted. just need to order the clutch too and get it all fitted...
no problem mate,
My WMI is fitted but not active as i've had to send the controller away for testing due to it being faulty we presume.
I've got the dual nozzle upgrade as well. I was only going to fit the one nozzle on the charge pipe but i've heard this has been known to mess up the MAP sensor. I have the 350-475 WHP Snow Performance nozzle on mine as this is what the car is making. Might have to re-think my nozzle placement and run it through the throttle spacer that came with the kit that i've yet to install.
Let me know how you get on. Keen to share info and experiences.
Any help getting the boot trim off .....?
Ye that bonnet bra looks cool on that! Don't think it would look that good on my silver beast tho lol
Reactions: Alex_Wil
Excellent read mate, your attention to detail is second to none!
pull hard mate, sorry that's all i can say. you may find that some of the clips stay on the car and be careful not to loose the rubber plugs on the back of the trim...
thanks mate...
cheers mate, i appreciate the comments...
as i'm pretty much there and ordered all the parts on my list i thought i'd post an update of my mods...
in other forums i have continually updated the first post each time a new mod has been added to my car so it keeps all the info in one spot and reduces the need for repeat posts. for some reason there is no edit on this forum so i won't be able to update this list as i go...
Engine:
2.0 TFSI Performance Turbocharger TTE420+ - not fitted
Tarmac Engineering SpecTune Upgrade Package (Inc Tune for WMI) – not fitted
Blue Flame Audi S3 Quattro 2.0 TFSi (Full 76mm System) 100 Cell Hi-Flow Cat
Evolution Motorsport 2.0T FSI V-Flow Intake
SPULEN Intake Manifold Runner Flap Delete Kit (SE-001) – not fitted
HPA Motorsports HPFP High Pressure Fuel Pump (HVA-270)
ECS Fuel Pump Cam Follower Replacement Kit (06D109309CKT)
Airtec Intercooler Upgrade for VAG 2.0 Petrol TFSI Including Black Hoses
BSH FSI Integrated Throttle Pipe Including Black Hoses(30306054)
Neuspeed HI-FLO K04 Turbo Discharge Including Black Hoses (48.02.69)
GFP DV+ Diverter Valve (T9351)
Torque Solution Billet Engine and Transmission Mount - 2.0T (TS-VW-012) – not fitted
SPULEN Engineering Dog Bone Engine Mount (SE-70116) – not fitted
SPULEN Dog Bone Engine Mount Insert Kit - Street (SE-70117)
Forge Motorsport Catch Can and PSV Delete with Boost Tap (FMMK5CTC)
OEM Audi TTRS Engine Cover (06F 103 925J)
OEM Audi Engine Cover Fitting Bolts (2x WHT000731A & 1x 06E103164E)
OEM Audi TTRS Low Pressure Fuel Pump (8J0919051E)
OEM Audi TTRS Fuel Pump Controller (8E0906071A)
OEM Audi G410 Low Pressure Fuel Pressure Sensor (06E906051K)
OEM Audi Fuel Filter (1K0201051K)
Tarmac Engineering 2.0 FSI High Pressure Rail Valve (155 Bar) – not fitted
Tarmac Engineering Water/Meth Throttle Body Spacer – not fitted
AEM V2 1-Gallon Water/Methanol Injection Kit with Internal MAP Sensor (30-3300) – not fitted
AEM Water/Methanol Injection Filter (30-3003) – not fitted
MAC 3 Port Boost Control Solenoid (35A-AAA-DDBA-1BA) – not fitted
Devils Own Water/Methanol Injection dual Nozzle Upgrade (2500) - not fitted
Devils Own Water/Methanol Injection Self Filtering Tank Tap (3019) - not fitted
Devils Own Water/Methanol Injection Check Valve (3031) – not fitted
Forge Expansion Bottle Cap and Oil Filler Cap (FMCAPS2-BLK)
Forge Silicone Carbon Canister Black Hose Kit (FMCCHMK5)
Forge Silicone Coolant Black Hose Kit (FMKC010)
Forge DV to Intake return Black Hose (FMRLH - 2L)
SPULEN 2.0T FSI Silicone Breather Black Hose (SE-022BLK)
SPULEN Brake Booster Black Hose Kit (SE-041)
ECS Billet Aluminium Oil Filter Housing – Silver Anodised (ES#2723776)
ECS Magnetic Sump Plug With 10 Copper Washers (ES#2804343)
PSI Tuning Aluminium Dipstick - 2.0TFSI (14100)
Transmission:
South Bend Stage 3 Daily Clutch and Flywheel Kit (KFSIF-SS-O)– not fitted
USP Stainless Steel Clutch Line - Audi/VW 6spd for RHD Vehicles (USP-004-78) – not fitted
Fluidampr Engine Damper 2.0TFSI (551211) – not fitted
Forge Adjustable Quick Shifter for VAG 6 Speed Models (FMVWQS)
Forge VAG 6 Speed Side Quick Shift (FMVWSQS)
42 Draft Designs VW Shifter Bushing Set (42-455-007)
Verdict Motorsports Shift Bracket Bushings (VMS100)
Suspension:
Haldex Performance Upgrade Gen 4 - 0BR Couplings Audi S3
Haldex Wireless Remote Control - Suits Gen 2 and Gen 4
35mm H&R Lowering Springs (29227-1)
Whiteline Front Sway bar - 24mm X heavy duty blade adjustable (BWF20XZ)– not fitted
Whiteline Rear Sway bar - 24mm X heavy duty blade adjustable (BWR21XZ)
Whiteline Control Arm - Lower Inner Rear Bushing - Anti-Lift/Caster Correction (KCA316)
SuperPro Roll Centre Adjusting Ball Joint (TRC0003)
Brakes:
OEM Audi TTRS Front Brake Callipers (8J0615107A and 8J0615108A)
OEM Audi TTRS Front Brake Discs (8J0615301F)
OEM Audi TTRS Front Brake Pads (8J0698151K)
RDA Dimpled and Slotted Rear Brake Discs (RDA7384D) – not fitted
Hawk Performance Ceramic Rear Brake Pad Set (HB544Z.628 )
034 Motorsport Stainless Steel Braided Brake Lines for Audi TTRS (034-303-0011) – rear not fitted
ATE Super Blue Racing Brake Fluid
Wheels:
Oettinger RE's 19x8.5 et50 5x112 Bolt Pattern
Borbet Hub Centric Rings (57.1mm to 68.00mm)
Goodyear Eagle F1 Asymmetric 235 35 19
Interior:
P3 Cars Integrated Vent Digital Gauge Audi 8P A3 (p3-vent-gauge-a3-tt-er)
P3 Cars Integrated Vent Digital Gauge Analogue boost sensor (P3BST100)
Dual OBD Port Connector (for P3 Gauge)
ECS Interior LED Lighting Kit (PL3642BA9KT1)
Bose Illuminated Speaker Grilles (CarStyle4you) – not fitted
S3 Glove Box Illuminated Handle (CarStyle4you) – not fitted
S3 Illuminated Dashboard Switches for WMI On/Off (CarStyle4you)
Audi Rings Illuminated Dashboard Status Indicator for WMI (CarStyle4you)
iPod Interface Alpine KCE-425i (IMA425I) – not fitted
ViseeO Tune2air WMA1000 - Wireless Bluetooth Music Interface Adapter – not fitted
Kufatec IMA Multimedia Adapter "Plus" (35538 ) – not fitted
Kufatec IMA - Harness - Audi RNS-E - "Basic"/"Basic-Plus" (35542) – not fitted
Kufatec IMA Control Wire - Stereo Jack 3.5 - Version 2 (35552) – not fitted
Kufatec Adapter - additional video Integration (35570) – not fitted
Kufatec IMA - Harness - Rear View Camera Auto Switch - Audi RNS-E (35676) – not fitted
Kufatec Complete set Rearview Camera Low Audi 8PA (39878)
Kufatec AMI Glove Box Storage for iPhone (37154)OEM SDS “Speech Dialogue System” UpgradeOEM Audi Ash Tray Delete (8P0863301A4P)OEM Audi Business Card Holder (8P0941561J)
OEM Universal Mobile Telephone Holder (4G0 051 435C) – not fitted
OEM Universal Mobile Telephone Cable for iPhone 6 (8V0 051 435E) – not fitted
OEM Microphone - BOSE Volume Fix (8E0 862 373A)
OEM Audi Antenna Fix (000098652A / 000098692 / 8P4035225B / 8P4035225 / 1C0973119B / 000979009)
OEM Audi Push Button Start (8E0863284E5PR / 8E0905217 / 8L0971883 / 000979009)
OEM Audi Under Seat Storage Drawer (8P08815814PK)
OEM Audi Cargo Net (8E5861869)
OEM Audi Rear Power Socket (8E0919309 / 7L6919341F)
Rear Cargo Boot Floor Rubber Liner
Exterior:
OEM Audi Black Edition Front Grille (8P0 853 651QVMZ)
OEM Audi Black Edition Driving Light Grilles (8P0807681PZDE / 8P0807682GZDE)
OEM Audi Black Edition B Pillar Covers (8P3853289DY9B / 8P3853290DY9B) – not fitted
OEM Audi Black Edition B Pillar Cover Rivet Fixings (N0161857) – not fitted
OEM Audi Front Number Plate Delete (8p0807287H) – not fittedOEM Audi MY11 Rear Light Clusters – (8P3945095C / 8P3945096C) – not fittedLED Front Driving Lights
LED Rear Number Plate LightsFront and Back Gloss Black Audi Rings
Front and Back Gloss Black S3 BadgesLaminex Smoked Protectors for Front Main Beam and Driving Lights – not fitted
Gecleant Glass Rear Wiper Delete Plug – not fitted
Secure a Plate Rear Number Plate Holder - 372mm x 100mm (1053)
Front Bonnet Lip Car Bra
ECS Jack Adaptor Pad Kit (ECS10724KT)
Reactions: HHS3 and Compkiler
Engine:
Transmission:
Suspension:
Brakes:
Wheels:
Interior:
Exterior:
:o.k: Now THAT'S a mod list! Your car's a peach! Credit to you, fella.
threaded rod for the hpfp...
before...
after a few swear words and some new tools...
blocked up the intake as it was time for a drink...
beer and a sit down was a good call...
more gunked up than i expected for 22,000 clicks...
replaced the ****** corrugated plastic pipe...
with a bit of silicone...
also replace some breather hoses
won't been needing these anymore...
and with the rfd kit installed...
a good opportunity to install the 155 bar rail valve too...
may as well install this at the same time...
no 2 nozzle for reference...
Reactions: Mario8P, Alex_Wil and S3Alex
Only one thing your missing really and that's the rs3 grill!
Would finish the car off totally! :)
i do like rs3 grilles, i prefer them on rs3's though. just going to stick with the standard s3 grille i reckon...
Reactions: downtothebone, grchmason and S3Alex
dropped the car in for a service, i didn't fancy fitting all this lot on my own...
Reactions: grchmason, Mario8P and S3Alex
Hey Guile
May I ask how did you route that silicone breather hose (the one from cylinder to valve cover)?
Can you please snap a photo for me? As mine is resting on the side plug of my HPFP. Couldn't find any better route
May I ask how did you route that silicone breather hose (the one from cylinder to valve cover)? Can you please snap a photo for me?
sorry about the delay getting back top you mate but I'm away at the moment without my car. i'm back in 2 weeks and will take a photo then if not too late...
Reactions: Mario8P
No problem mate
I'll be waiting. Have a safe trip
